Measure of frequency
Hi
I want to measure the frequency signal output oh ad5930 so i use the code
#include <FreqCount.h>
  Serial.begin(57600);
  FreqCount.begin(1000);
  if (FreqCount.available()) {
    unsigned long count = FreqCount.read();
    Serial.println(count);
these is the reference of code http://www.pjrc.com/teensy/td_libs_FreqCount.html
when i use it the serial always show 0 i connect the output of the ad5930 to pin 5 and the GND of ad5930 to GND of arduino board
can someone help me please
Are you using a teensy?
Have you set up the ad5930 to output a known frequency so that you can test that sketch?
Pete
no i don't use a teensy robtillaart i have the eval ad5930 and arduino uno and lcd to display the frequency
el_supremo yes i made the output of the ad5930 to 120 hz but no outcome :~
What you're doing looks correct, so I wonder whether the 'ad5930' (whatever that is) is powered correctly and actually outputting a signal on the pin you expect with sufficient amplitude to trigger the digital input. You could try just doing a digital read of pin 5 repeatedly and see what values you're getting back? If it's working as you expect, you should see it returning both HIGH and LOW; if it always returns HIGH or always returns LOW that suggests the ad5930 isn't doing what you want.
A cheap digital multimeter with a frequency function is a great diagnostic tool.
...R
