I want to measure the output of the Blink example with the oscilloscope Tektronix TDS 1001. In the example the Build-In LED pin on an Arduino Zero should be 1s high, 1s low. This works. But if I measure it with the oscilloscope I get a weird sine wave with much noise. Not a square wave, definitely false.
Does someone know what are the settings for the oscilloscope to measure it? For example coupling, ... I have tried a lot of different setting, but I get always the same result.
Why should I set it to DC? I see now something with AC
yes ground is connected on the arduino ground
I found out want my problem is:
I measure a 10us peak which occurs every second. So very different timescales. Is there a solution that I can see this peak on the oscilloscope with a timesetting of 500ms for example?
I guess not..
But I was measured with AC not DC. I see nothing on DC
