measure respiration rate
What's the smartest and simplest way to measure respiration rate? Preferably, non invasively.
It's for an art project, where a person sits in a spot. Their breath will control lights and sounds. I want the lights and sounds to match the breath.
I can control exactly where they sit. I can also control in what position they sit. I can make them wear stuff. But for best effect it should be something where they just need to sit. Then a functionary doesn't need to be present.
Will an IR camera work? Or doesn't the breath change the body temperature enough?
I've also thought about a stretchy band around the chest, and then measure tension/stress. But I don't know which sensor that is.
Please help? Any ideas would be valuable. Not sure which route to go
how you want to measure it, by detecting pressure or temperature? there are ways by using temp sensor, using pressure gauge, u can also use microphone.
EJLED:
Any method that works is good. As long as it gets the job done, I have no opinion on method.
There might be background noise. So I think a microphone might not be reliable.
