Measure separate voltage of each battery connected in series
The project requirement is that to measure the voltage of each battery separately from the whole connection of 4 battery that connected in series. This is my connection and with always explode the resistor when I start to connect the second or third battery. Is there any solution for this? Please help.
If I put this schematic connection in to the arduino simulator on thinkercad its shown 0.00vol for A2, A3, A4 but A5 shown correct value.
You know there's a button or tab on that F**ing system called "Schematic"? Use it. It may take a little more effort to get it looking neat without overlapping lines but it's a thousand times more readable.
Multiple overlapping wires and pictures of batteries you don't have are distractions to the problem.
Welcome to the forum.
http://forum.arduino.cc/index.php/topic,148850.0.html .
Then look down to item #7 about how to post your code.
It will be formatted in a scrolling window that makes it easier to read.
If you actually draw a proper circuit diagram of your project, you will see why you have a problem.
