Measure shock size with The CurieIMU library
Hello guys,
I’m currently working on a project where I would like to detect a shock everytime I take a step with a crutch, and more specific output the “size” of the shock, so I can compare the shock/vibrations when walking on different surrfaces with the crutch.
I’m using the CurielIMU library, together wih an Arduino 101 which is attached to the crutch, to detect the shock everytime I take a step, and it works really well. However, I’m unsure on how to measure and output the “size” of the each vibration/shock. Right now I meassure the acceleration and rotation of the Arduino in x,y,z space by running the CurieIMU.readMotionSensor(ax, ay, az, gx, gy, gz); in the loop. Every time a shock is detected, the measured ax, ay and az is printed to the serial.monitor.
It’s possible to set the Shock threshhold in “mg” and I guess this measured “mg” is what I’m looking for. But the values I get from ax, ay and az when a shock is detected, dosen’t really make sense to me:
The following code is 4 readings from tapping the crutch soft into a pillow
acc: 1.58 -2170 10123
acc: 1.74 -1365 11205
acc: 1.59 -1671 11419
acc: 1.99 -1017 10117
And the next 4 readings is from harder taps into a wooden floor.
acc: 1.67 -6678 10631
acc: 1.83 -1487 167
acc: 1.80 -4050 8429
acc: 1.93 5119 -4129
I can't really se a relation to my movement and the outputs, so if I would like to output the "shock size” which might be the mg value compared to the treshhold, how does I measure that and output it correctly?
here is my code.
#include "CurieIMU.h"
boolean blinkState = false;          // state of the LED
int ax, ay, az;
int gx, gy, gz;  // not used
float aix, aiy, aiz;
int calibrateOffsets = 1;
  Serial.begin(9600); // initialize Serial communication
  while(!Serial) ;    // wait for serial port to connect..
  /* Initialise the IMU */
  CurieIMU.begin();
  CurieIMU.attachInterrupt(eventCallback);
  // use the code below to calibrate acc offset values
  if (calibrateOffsets == 1) {
    Serial.println("Internal sensor offsets BEFORE calibration...");
    Serial.print( CurieIMU.getAccelerometerOffset(X_AXIS));
    Serial.print("\t"); // -76
    Serial.print(CurieIMU.getAccelerometerOffset(Y_AXIS));
    Serial.print("\t"); // -235
    Serial.println(CurieIMU.getAccelerometerOffset(Z_AXIS));
    CurieIMU.setAccelerometerOffset(X_AXIS,495.3);
    CurieIMU.setAccelerometerOffset(Y_AXIS,-15.6);
    CurieIMU.setAccelerometerOffset(Z_AXIS,491.4);
  /* Enable Shock Detection */
  CurieIMU.setDetectionThreshold(CURIE_IMU_SHOCK, 1500); // 1.5g = 1500 mg
  CurieIMU.setDetectionDuration(CURIE_IMU_SHOCK, 500);   // 50ms
  CurieIMU.interrupts(CURIE_IMU_SHOCK);
  Serial.println("IMU initialisation complete, waiting for events...");
  // measure raw acceleration.
  CurieIMU.readMotionSensor(ax, ay, az, gx, gy, gz); //the gyroscope measurements aren't used.
  // concert raw data to mg
  aix = convertRawAcceleration(ax);
  aiy = convertRawAcceleration(ay);
  aiz = convertRawAcceleration(az);
  //digitalWrite(13, blinkState);
  //blinkState = !blinkState;
  delay(1);
static void eventCallback(void)
  if (CurieIMU.getInterruptStatus(CURIE_IMU_SHOCK)) {
    Serial.print("a/g:\t");
    Serial.print(aix);
    Serial.print("\t");
    Serial.print(ay);
    Serial.print("\t");
    Serial.println(az);
    if (CurieIMU.shockDetected(X_AXIS, POSITIVE))
      Serial.println("Negative shock detected on X-axis");
    if (CurieIMU.shockDetected(X_AXIS, NEGATIVE))
      Serial.println("Positive shock detected on X-axis");
    if (CurieIMU.shockDetected(Y_AXIS, POSITIVE))
      Serial.println("Negative shock detected on Y-axis");
    if (CurieIMU.shockDetected(Y_AXIS, NEGATIVE))
      Serial.println("Positive shock detected on Y-axis");
    if (CurieIMU.shockDetected(Z_AXIS, POSITIVE))
      Serial.println("Negative shock detected on Z-axis");
    if (CurieIMU.shockDetected(Z_AXIS, NEGATIVE))
      Serial.println("Positive shock detected on Z-axis");
float convertRawAcceleration(int aRaw) {
  float a = (aRaw * 2.0) / -32768.0;
  return a;
I suggest to not use the library for shock detection until you have a better understanding of what the measurements mean.
Try measuring accelerations as rapidly as you can, printing (or better, plotting) them out and learn to understand what they report during a "shock".
If printing, keep in mind that printing is slow, so use the highest baud rate possible on the serial monitor.
Incidentally there is a problem in the way that your program prints the x versus y and z accelerations.
