I am trying to measure bending strain in a bar with BF350 in half bridge configuration interfaced with HX711 to arduino.
I want minimum strain to maximum strain ratio of 1:10000, is it possible? Means, if full scale is set to 10000, the minimum granularity should be better than 1 for eg ability to measure 10 Kgm as well as 1 gm.
10kg : 1g is 10000:1, but Arduino ADC is 10 bit (1024:1).
Also the mechanical hysteresis will hide any real signal - you need a smaller load cell for your 1g range, this is
chemical balance territory, not kitchen scales.
