Measure time difference between two nrf24 modules. One is changing position.
3xdamag3:
All I can share is that there will be up to 30 steps with 3-5 cm between them, the maximum distance for sep nr 30 will be around 50cm from the device fixed.
With that information unfortunately I can only recommend you use Google for distance sensors.
The possibilities are endless without more information. Many applications figured out short distances even cheap ones like 3D printers or old computer mouses but also industrial machines or vending machines using mechanics.
I suggest using quantum entangles electrons. When the transmitter begin the transmission, tell it's quantum device to switch the spin on it's electron. The quantum device on the receiving end detects the spin change on it's electron and begins the count down to when the receiver detects the beginning of a message. The difference in time is now how long it takes for the message to begin to arrive. Save this time.
Move the transmitter and it's quantum device and repeat. The difference in times is now because of the new distance.
Easy peasy!
Paul
All I can share
Advice requested for a Top Secret Project, on an open source technical hobby forum!
Very clever idea.
jremington:
Again, not with hobby equipment. See reply #5.
A tape measure can be used to measure distances between objects, and the time for transmission can be calculated. Divide the distance by the speed of light, 3x1010 cm/sec.
Agian, do you have some equipment in mind? https://www.nordicsemi.com ?
I have lots of knowledge in regards to distance sensors ToF, lidar, ultrasonic, etc. Due to the physical environment with objects in the way of the devices, they will not work. So all I have of options are down to do R&D to find out if it's possible with RF, BLE(RSSI), and RFID.
jremington:
Very clever idea.
You are a smart guy with lots of knowledge I guess. I want your expertise and opinion on the problem I'm working on. The detail that is important for the matter is shared in detailed pictures and words. What is a "clever idea" is very relative, depending on perception and way of thinking.
3xdamag3:
You do not seem to be able to accept the FACT that what you are asking is not physically possible, nor even theoretically possible.
Paul
Paul_KD7HB:
Paul
Thanks for you help and response Paul.
Your FACT that this "might" not work because its physically not possible. That sir, is why I will prove you wrong.
I will share the solution here, so you can make another opinion about what is FACT and what is not. Thanks for you help anyway.
3xdamag3:
Waiting.
