Hello Everyone,
Fairly new to C# and Arduino programming here...
Ill try and make this quick, so my question is i need to program my nano to (As the subject says):
Measure Total Time a Push Button Is Set To HIGH and when Desired Time Is Reached turn on a LED...
To clarify, i want the nano to measure the time a push button attached to digital pin 4 is read HIGH (push button not pressed is LOW) and i need to be able to make multiple presses on the button and have the total time saved and accrued (added) each time it goes HIGH, and when a total of 10 seconds of time is measured of the button being HIGH, a LED on Digital pin 5 turns on.
so for example if i push the button for 2 seconds the nano will save the total time of 2 seconds and wait for me to press it again, now when i press the button for 6 seconds the program will add 2 + 6 = 8 and when if my next move of pressing the button again for 3 seconds the program will limit my press to 2 seconds because 8 + 2 = 10 and will then turn on the LED and do nothing if the button is pressed again...
hope this is clear enough... i dont have any code yet to post but if anyone could help me out with something to start with, i would greatly appreciate it.
thanks
MrGmo
