Measure Water level on a 20m depth well
Hello Arduino Community , im from Portugal and very fresh arduino user.
I already played a litlle bit with some projects that i found on the forum ( displays mostly ).
I'm looking to start my first real arduino project with an very usefull tool for me that is the measurement of the water level on my well.
The conditions are:
  • Well depth : ~20m
  • Well diameter : ~1.8m
  • Water level range measured ( manually ) so far : 1m to 16m
I'm insterested on members opinion about the best way to achieve a satisfatory result on the reading of the water depth ( for home use ).
Very thanks in advanced for keep this community alive and always usefull .
Sorry my rusty english.
Joao
Have a great respect for “the environment” especially humidity involved with water. Is the well sitting indoors or outdoors?
Both the controller and the sensor are sensitiv devices.
Hi Joao,
Your English is good enough to understand. There exists a Portugues section which might or might no be useful too to find people nearby that can actually help on location.
That said, there are several ways to measure depth of the water and to give a good advice we need more information.
  • how exact must the measurement be
  • how often do you want to measure
  • is there a power (e.g. 230V nearby or battery operated)
  • can you modify the well (e.g. add a sensor every meter)
  • budget?
The well is on the center of a closed garage and its closed with a heavy cement lid , we can consider it is indoors.
Welcome to the Arduino forum. Have you used the forum search tool to see what others have done for similar projects?
With water level being 16m, you must be using a submersible pump. So what electrical power is available at the well to power your Arduino project?
Replying your questions …
   Would be satisfied with a 30 or 50 cm gap
   it can be every 2 hours (
   i have 230v and also an 2 tubes that allows me to insert power or data cabes insed the well
  it could possible
  • budget?
  as lower as possible but i need to works :)
A pressure sensor near the bottom of the well will accurately report the water depth(*). Pressure increases linearly with height of water column above the sensor. You can buy immersible sensors designed for that purpose.
(*) for highest accuracy, buy a "gauge" sensor rather than an absolute pressure sensor, which will also respond to changes in atmospheric pressure.
  • Perhaps a long closed at the top (i.e. air tight) pipe placed in the water with an air pressure sensor in the top would work.
    When the water level increases, the air pressure in the pipe increases.
    Arduino converts air pressure to water height.
    :thinking:
OR
  • A float with arm pushing on a strain gauge ?
I am not sure this will help but in my Coy pond I have a bubblier that runs 24/7. I put a pressure transducer on it and the pressure varies with the depth of the water. It a sensitive MPX from Motorola. That will give you an idea of how long it has been there. They are non labeled NPX I believe. I do not know if this will help but the sensor is about 30 meters away in the house as is the air pump, modified to use outside air to keep from freezing in the winter.
Not in the long run, as the trapped air will dissolve into the water and the pipe will slowly fill.
People use bubblers for that reason (the pressure required to force a bubble out of the pipe opening has to be just slightly higher than the water pressure at the opening).
  • A reel (purple) releases a line (orange) with a float (red) and a mass (black) at the end.
  • The weight of the mass pushes down on a pulley (gray).
  • A moment arm (green) attached to the pulley presses a button (blue)
  • The mass/float is lowered
  • When the float reaches the water, it holds the weight in place, releasing pressure on the line which un-weights the pully and releases the button.
  • Count revolutions of the reel as the mass/float are lowered to determine the approximate distance.
How do you think any sensor will be usable with the lid on the well?
Have a look at the MS5837-30 sensor which can be used for depths down to 30 meters.
Wrote a library for it in the past
I've had a look at some water supply (regional) wells and even some of the biggest, 2-m diameter, up to 100-m deep, and none had water depth monitoring.
A supply well isn't just a deep hole, but is often like an oil well with branches going out horizontally called addits.
Instead, a submersible pump had high and low level switches and that part of the system was telemetered. The submersible pump, run on off-peak electricity, was simply used to top up supply reservoirs.
For shallow tanks, reservoirs etc., ultrasonics can be used, but for reliability, floats of some description are favoured.
A closed well can be a fairly hostile environment with high humidity and condensation.
Traditionally, and reliable is the tape measure equipped with conductivity electrodes.
Less reliable, the dropped pebble method.
I am experimenting with cheap air pressure sensors for the same problem.
If you attach a flexible tube with a weight on the end and a simple filter like a fish tank aerator, when you drop it in the well, it will return a pressure relative to the depth it sinks. This is independent of any other factors except ambient air pressure.
As long as the tube is impermeable to air and water, once calibrated the depth will be accurate to within 1/x of the target range depending on the sensor used.
A second sensor measuring ambient air pressure would give an accurate continuous offset.
Google is full of methods .
Because of the environment you need industrial quality devices
It has been mentioned but I suggest a Google of “water level bubbler method” that will get you some ideas. Did you want to check water level occasionally or display it 24/7?
Ron
