I'm trying to get a measurement from my ADC on an Arduino Uno rev3 using different prescaling factors. I have connected a pot at A0 to be able to modify the voltage. When the measurement is higher than 300, a pulse is output at pin 6, otherwise a constant value is output. Here is my source code:
#include <Arduino.h>
#include <avr/io.h>
#include <avr/interrupt.h>
#define _FREE_RUNNING_MODE 100
#define _SIGNLE_CONVERSION_MODE 101
#define mode _FREE_RUNNING_MODE
#define prescalingFactor 2
int main(void)
DDRC &= ~(1<<DDC0); // Pin A0 as Input
DDRD |= (1<<PIND7);//Pin 6 on arduino as output
if (prescalingFactor==16){
ADCSRA |= 1<<ADPS2;
else if (prescalingFactor==2){
ADCSRA |= 1<<ADPS0;
else if (prescalingFactor==4){
ADCSRA |= 1<<ADPS1;
else {
//default to 128
ADCSRA |= 1<<ADPS2 | 1<<ADPS1 | 1<<ADPS0;
ADMUX |= (1<<REFS0) | (1<<REFS1); // Internal 1.1V reference
if (mode==_FREE_RUNNING_MODE){
ADCSRB &= ~((1<<ADTS2)|(1<<ADTS1)|(1<<ADTS0));//ADC in free-running mode
ADCSRA |= (1<<ADATE);//Signal source, in this case is the free-running
ADCSRA |= 1<<ADIE; // Enable the interrupt
ADCSRA |= 1<<ADEN;// Enable the ADR
sei();// Enable Interrupts (Global)
ADCSRA |= 1<<ADSC;//Start first conversion (necessary always)
while(1){
ISR(ADC_vect)
uint8_t lowPart = ADCL;
uint16_t myMeasurement = ADCH<<8 | lowPart;
if (mode==_SIGNLE_CONVERSION_MODE) {
ADCSRA |= 1<<ADSC;
}//trigger new conversion
if (myMeasurement>=300){
PIND ^= 1<<PIND6;//flip pin 6 on arduino
For debugging I use Serial.println(myMeasurement);
inside the while(1){}
loop. Everything works as expected for every prescaling factor greater than 2 (4,8,...,128). But, when I set the prescaler's division factor to 2 (i.e. 8MHz):
- I constantly get a pulse at the output, meaning that it seems that
myMeasurement>300
holds true regardless of the position of the potentiometer. - If I use Serial.println for debugging, I get the measurement
1023
always.
Any ideas? Why isn't my measurement updated on runtime?
