Measurement of Dissolved Oxygen, pH and Conductivity together in one monitor
Dear All,
I am able to read the pH, E.C. and DO values separately in separate serial monitors one at a time. Is it possible to take these measurements on one serial monitor without having to merge the codes in one file?
data sheets are as under:
https://www.atlas-scientific.com/_files/_datasheets/_circuit/ph_EZO_Datasheet.pdf
https://www.atlas-scientific.com/_files/_datasheets/_circuit/ec_EZO_Datasheet.pdf
The codes for reading the measurements are below:
Dissolved Oxygen:
#include <Wire.h>                //enable I2C.
#define address 97               //default I2C ID number for EZO D.O. Circuit.
char computerdata[20];           //we make a 20 byte character array to hold incoming data from a pc/mac/other.
byte received_from_computer = 0; //we need to know how many characters have been received.
byte code = 0;                   //used to hold the I2C response code.
char DO_data[20];                //we make a 20 byte character array to hold incoming data from the D.O. circuit.
byte in_char = 0;                //used as a 1 byte buffer to store inbound bytes from the D.O. Circuit.
int time_ = 600;                 //used to change the delay needed depending on the command sent to the EZO Class D.O. Circuit.
float DO_float;                  //float var used to hold the float value of the DO.
char *DO;                        //char pointer used in string parsing.
char *sat;                       //char pointer used in string parsing.
float do_float;                  //float var used to hold the float value of the dissolved oxygen.
float sat_float;                 //float var used to hold the float value of the saturation percentage.
void setup()                    //hardware initialization.
  Serial.begin(9600);          //enable serial port.
  Wire.begin();                //enable I2C port.
void loop() {                   //the main loop.
  byte i = 0;                   //counter used for DO_data array.
  if (Serial.available() > 0) {                                           //if data is holding in the serial buffer
    received_from_computer = Serial.readBytesUntil(13, computerdata, 20); //we read the data sent from the serial monitor(pc/mac/other) until we see a <CR>. We also count how many characters have been received.
    computerdata[received_from_computer] = 0;                             //stop the buffer from transmitting leftovers or garbage.
    computerdata[0] = tolower(computerdata[0]);                           //we make sure the first char in the string is lower case.
    if (computerdata[0] == 'c' || computerdata[0] == 'r')time_ = 600;     //if a command has been sent to calibrate or take a reading we wait 600ms so that the circuit has time to take the reading.
    else time_ = 300;                                                     //if not 300ms will do
    Wire.beginTransmission(address);                                      //call the circuit by its ID number.
    Wire.write(computerdata);                                             //transmit the command that was sent through the serial port.
    Wire.endTransmission();                                               //end the I2C data transmission.
    if (strcmp(computerdata, "sleep") != 0) {  //if the command that has been sent is NOT the sleep command, wait the correct amount of time and request data.
                                               //if it is the sleep command, we do nothing. Issuing a sleep command and then requesting data will wake the D.O. circuit.
    delay(time_);                     //wait the correct amount of time for the circuit to complete its instruction.
    Wire.requestFrom(address, 20, 1); //call the circuit and request 20 bytes (this may be more than we need)
    code = Wire.read();               //the first byte is the response code, we read this separately.
    switch (code) {                   //switch case based on what the response code is.
      case 1:                         //decimal 1.
        Serial.println("Success");    //means the command was successful.
        break;                        //exits the switch case.
      case 2:                         //decimal 2.
        Serial.println("Failed");     //means the command has failed.
      case 254:                      //decimal 254.
        Serial.println("Pending");   //means the command has not yet been finished calculating.
      case 255:                      //decimal 255.
        Serial.println("No Data");   //means there is no further data to send.
    while (Wire.available()) {       //are there bytes to receive.
      in_char = Wire.read();         //receive a byte.
      DO_data[i] = in_char;          //load this byte into our array.
      i += 1;                        //incur the counter for the array element.
      if (in_char == 0) {            //if we see that we have been sent a null command.
        i = 0;                       //reset the counter i to 0.
        break;                       //exit the while loop.
    if (isDigit(DO_data[0])) {
      string_pars();                  //If the first char is a number we know it is a DO reading, lets parse the DO reading
    else {                            //if it’s not a number
      Serial.println(DO_data);        //print the data.
      for (i = 0; i < 20; i++) {      //step through each char
        DO_data[i] = 0;               //set each one to 0 this clears the memory
void string_pars() {                  //this function will break up the CSV string into its 2 individual parts, DO and %sat.
  byte flag = 0;                      //this is used to indicate is a “,” was found in the string array
  for (i = 0; i < 20; i++) {          //Step through each char
    if (DO_data[i] == ',') {          //do we see a ','
      flag = 1;                       //if so we set the var flag to 1 by doing this we can identify if the string being sent from the DO circuit is a CSV string containing tow values
  if (flag != 1) {                    //if we see the there WAS NOT a ‘,’ in the string array
    Serial.print("DO:");              //print the identifier
    Serial.println(DO_data);          //print the reading
  if (flag == 1) {                    //if we see the there was a ‘,’ in the string array
    DO = strtok(DO_data, ",");        //let's pars the string at each comma
    sat = strtok(NULL, ",");          //let's pars the string at each comma
    Serial.println(DO);               //print the reading
    Serial.print("Sat:");             //print the identifier
    Serial.println(sat);              //print the reading
    flag = 0;                         //reset the flag
    /*                                //uncomment this section if you want to take the ASCII values and convert them into a floating point number.
    DO_float=atof(DO);
    sat_float=atof(sat);
Thank you very much Delta_G. I am trying to combine the codes for all these sensors but getting compile error. I am still in the process of learning. Can you please share any code that combines various sensors to read all at the same time for myself to learn doing it?
I would be very grateful to you as im in the middle of my project and stuck at this stage.
What a pity you didn't share it with us.
Thanks Global Moderator. Actually i did try to include all the sensor codes but it was exceeding the number of words allowed. i am trying post the codes for E.C. and pH again as Dissolved oxygen code was posted in my first post.
//**Code for measuring electrical conductivity**
#define address 100              //default I2C ID number for EZO EC Circuit.
bool serial_event = false;       //a flag to signal when data has been received from the pc/mac/other.
char ec_data[48];                //we make a 48 byte character array to hold incoming data from the EC circuit.
byte in_char = 0;                //used as a 1 byte buffer to store inbound bytes from the EC Circuit.
byte i = 0;                      //counter used for ec_data array.
int delay_time = 600;            //used to change the delay needed depending on the command sent to the EZO Class EC Circuit.
char *ec;                        //char pointer used in string parsing.
char *tds;                       //char pointer used in string parsing.
char *sal;                       //char pointer used in string parsing.
char *sg;                        //char pointer used in string parsing.
float ec_float;                  //float var used to hold the float value of the conductivity.
float tds_float;                 //float var used to hold the float value of the TDS.
float sal_float;                 //float var used to hold the float value of the salinity.
float sg_float;                  //float var used to hold the float value of the specific gravity.
void serialEvent() {                                                        //this interrupt will trigger when the data coming from the serial monitor(pc/mac/other) is received.
  serial_event = true;                                                      //set the serial event flag.
  if (serial_event == true) {                                               //if a command was sent to the EC circuit.
    if (computerdata[0] == 'c' || computerdata[0] == 'r')delay_time = 600; //if a command has been sent to calibrate or take a reading we wait 600ms so that the circuit has enough time to take the reading.
    else delay_time = 300;                                                  //if any other command has been sent we wait only 300ms.
        //if it is the sleep command, we do nothing. Issuing a sleep command and then requesting data will wake the EC circuit.
      delay(delay_time);                                                    //wait the correct amount of time for the circuit to complete its instruction.
      Wire.requestFrom(address, 48, 1);                                     //call the circuit and request 48 bytes (this is more than we need)
        ec_data[i] = in_char;                    //load this byte into our array.
      Serial.println(ec_data);                  //print the data.
    serial_event = false;                      //reset the serial event flag.
    //if(computerdata[0]=='r') string_pars(); //uncomment this function if you would like to break up the comma separated string into its individual parts.
void string_pars() {                  //this function will break up the CSV string into its 4 individual parts. EC|TDS|SAL|SG.
                                      //this is done using the C command “strtok”.
  ec = strtok(ec_data, ",");          //let's pars the string at each comma.
  tds = strtok(NULL, ",");            //let's pars the string at each comma.
  sal = strtok(NULL, ",");            //let's pars the string at each comma.
  sg = strtok(NULL, ",");             //let's pars the string at each comma.
  Serial.print("EC:");                //we now print each value we parsed separately.
  Serial.println(ec);                 //this is the EC value.
  Serial.print("TDS:");               //we now print each value we parsed separately.
  Serial.println(tds);                //this is the TDS value.
  Serial.print("SAL:");               //we now print each value we parsed separately.
  Serial.println(sal);                //this is the salinity value.
  Serial.print("SG:");               //we now print each value we parsed separately.
  Serial.println(sg);                //this is the specific gravity.
  //uncomment this section if you want to take the values and convert them into floating point number.
    ec_float=atof(ec);
    tds_float=atof(tds);
    sal_float=atof(sal);
    sg_float=atof(sg);
What a pity you didn't share the compilation errors you're seeing.
I could not post my combined code due to size exceeded the allowed size, hence attached.
And im getting these errors.
do_EC_pH:125: error: expected unqualified-id before 'if'
do_EC_pH:128: error: expected unqualified-id before 'else'
exit status 1
do_EC_pH.ino (9.81 KB)
I'm not sure what the difficulty is. You have three peripherals on the 12c bus, on addresses 97, 99, and 100. Your arduino listens to the serial. When it receives a message, it parses that message and kicks off a process that talks to the relevant peripheral.
As for your syntax errors, you have way too many closing braces. Use ctrl/cmd-T to auto format.
This:
    Wire.beginTransmission(address_DO);                                      //call the circuit by its ID number.
    Wire.beginTransmission(address_EC);
    Wire.beginTransmission(address_pH);
really isn't going to work. An i2c bus talks to one thing at a time.
If I was going to write a sketch for you in Gigs and Collaborations, I'd ask "what, exactly, do you want to send to the arduino on the serial, and what, exactly, do you require the arduino to send back"? The PDFs you linked to are fairly clear on what needs to be sent to the peripherals.
i want to send all the measurements from these sensors on the serial monitor which i then want to send to labview serial interface. can you please suggest the way forward?
Why do you want it on the serial monitor AND then sent on to LabView? That's hard.
Doesn't LabView have the means to display data?
There is no block in labview that would connect to Ameba RTL8195 board im using. I have already displayed individual sensor's measurement on labview serial communication (continuous serial read and write program) after running the sensor's program on Ameba and sending it to serial monitor. the reason of using labview is the display and interface features it offers.
sal_murd:
I'm not sure what the 'labview serial interface' might be. Do you mean there's some sort of piece of equipment that connects to a different pin on the arduino?
As for the readings, you open i2c to each in turn and ask them to take a reading. You then poll each of them with maybe a delay between retries until you no longer get the 'still processing' status. The result from each might be an error or might be the data you need.
PaulMurrayCbr:
I am not able to open i2c to each sensor as it generates error. my code for taking readings from 2 sensors is attached as i could not include code here due to maximum allowed character length.
The error I receive is :
Arduino: 1.8.1 (Windows 7), Board: "Ameba RTL8195A"
C:\Users\eng.EEPROJ-DP.000\Desktop\ph_ec_do\ph_ec_do.ino: In function 'void setup()':
ph_ec_do:147: error: redefinition of 'void setup()'
ph_ec_do:40: error: 'void setup()' previously defined here
C:\Users\eng.EEPROJ-DP.000\Desktop\ph_ec_do\ph_ec_do.ino: In function 'void loop()':
ph_ec_do:155: error: redefinition of 'void loop()'
ph_ec_do:49: error: 'void loop()' previously defined here
exit status 1
option enabled in File -> Preferences.
ph_ec_do.ino (11.3 KB)
I have tried to combine the code as attached. (again due to maximum allowed character length)
getting error as:
ph_ec_do:109: error: 'pH_data' was not declared in this scope
pH_data = in_char_pH;
    ph_ec_do:117: error: 'pH_data' was not declared in this scope
    pH_data*=in_char_pH;
    _
    ^_
    ph_ec_do:119: error: 'string_pars' was not declared in this scope
    string_pars(); //If the first char is a number we know it is a DO reading, lets parse the DO reading*
    ph_ec_do:133: error: a function-definition is not allowed here before '{' token
    ph_ec_do:163: error: expected '}' at end of input
    exit status 1
    can you please help me correct the mistake?
    ph_ec_do.ino (9.12 KB)
I have combined the code for pH and dissolved oxygen but now i can only read from pH sensor giving a wierd reading :
Success
.0
DO:400
.0
DO:400
From the LED on the sensor, i can see only the pH sensor LED blinks green on reading.
code is attached , please check and support.
ph_ec_do.ino (9.53 KB)
Dear all,
please help in reading the sensors (dissolved oxygen and pH). My code is attached as i could not included here due to maximum allowed length of the message.
According to the datasheets provided, sending character R results in reading and gives measurement.however, im only able to read dissolved oxygen sensor and not pH(i can observe the green LED blink on the sensor). The response on serial monitor is as below:
No Data from pH
No Data from pH
No Data from pH
No Data from pH
No Data from pH
kindly please help
ph_ec_do.ino (10.1 KB)
If you got rid of some of the pointless comments, I bet you could post your code, no problem.
Here is the code,
#include <Wire.h>
#define address 97
#define address_pH 99
byte code = 0;
char DO_data[20];
byte in_char = 0;
int time_ = 900;
float DO_float;
char *DO;
char *sat;
float do_float;
float sat_float;
char computerdata_pH[20];
byte received_from_computer_pH = 0;
byte code_pH = 0;
char pH_data[20];
byte in_char_pH = 0;
byte i = 0;
int time_pH = 900;
float ph_float;
  Wire.begin();
  byte i = 0;
    if (computerdata[0] == 'c' || computerdata[0] == 'r')time_ = 900;
    else time_ = 300;
      delay(time_);
      code = Wire.read();
      switch (code) {
        case 1:
        case 2:
        case 254:
        case 255:
          Serial.println("No Data from do");
      i += 1;
      if (in_char == 0 || in_char_pH == 0) {
        delay(100);
        Wire.beginTransmission(address_pH);                                      //call the circuit by its ID number.
        Wire.write(computerdata_pH);                                             //transmit the command that was sent through the serial port.
        if (strcmp(computerdata_pH, "sleep") != 0) {  //if the command that has been sent is NOT the sleep command, wait the correct amount of time and request data.
    else time_ = 300;
       delay(time_pH);
       Wire.requestFrom(address_pH, 20, 1);
          code_pH = Wire.read();
          switch (code_pH) {
            case 1:
            case 2:
            case 254:
            case 255:
              Serial.println("No Data from pH");
      in_char_pH = Wire.read();
      pH_data[i] = in_char_pH;
      i += 1;
      if (in_char_pH == 0) {
        i = 0;
         Serial.println(pH_data);
      DO_float=atof(DO);
Only reading is from dissolved oxygen sensor.
Programming hint: to avoid per-line comments, make your code read like a story.
Example, your function "string_pars"[sic].
You have a variable called "flag".
Is it any particular flag?
Yes it is - it indicates the presence or absence of a comma.
So why not make it a Boolean, and call it 'commaFound" ?
Then a simple if/else will suffice.
I have modified my code and can read both sensors but only after sending a character R in the serial monitor. is there any way to include sending R in the code in itself so as get the readings without user intervention? please help , my code is under:
#include <Wire.h>
#define address 97
byte code = 0;
char DO_data[20];
byte in_char = 0;
int time_ = 900;
float DO_float;
char *DO;
char *sat;
float do_float;
float sat_float;
byte code_pH = 0;
char pH_data[20];
byte i = 0;
int time_pH = 900;
float ph_float;
  Wire.begin();
  byte i = 0;
    else time_ = 300;
      delay(time_);
      code = Wire.read();
      switch (code) {
        case 1:
        case 2:
        case 254:
        case 255:
      i += 1;
        delay(100);
    else time_ = 300;
       delay(time_pH);
          switch (code_pH) {
            case 1:
            case 2:
            case 254:
            case 255:
      i += 1;
        i = 0;
      DO_float=atof(DO);
Please suggest the method for Sending character R followed by carriage return in the program itself rather than for user input in the serial monitor to read from these sensors.
#include <Wire.h>
#define DEV_ID 0x61   //DO
#define DEV_ID2 0x63    //pH
#define DEV_ID3 0x64  //EC
byte code = 0;
char DO_data[20];
byte in_char = 0;
int time_ = 600;
float DO_float;
char *DO;
char *sat;
float do_float;
float sat_float;
char computerdata_EC[20];
byte received_from_computer_EC = 0;
byte code_EC = 0;
char ec_data[48];
byte in_char_EC = 0;
byte i = 0;
char *ec;
char *tds;
char *sal;
char *sg;
float ec_float;
float tds_float;
float sal_float;
float sg_float;
char pH_data[20];
int time_pH = 900;
  Wire.begin();
  Wire.beginTransmission(DEV_ID);
  Wire.write(0x52);
  Wire.begin();
  Wire.beginTransmission(DEV_ID2);
  Wire.write(0x52);
  Wire.beginTransmission(DEV_ID3);
  Wire.write(0x52);
  byte i = 0;
    else time_ = 300;
    Wire.beginTransmission(DEV_ID);                                      //call the circuit by its ID number.
      delay(time_);
      Wire.requestFrom(DEV_ID, 20, 1);
      code = Wire.read();
      switch (code) {
        case 1:
        case 2:
        case 254:
        string_pars();
      else {
          DO_data[i] = 0;
      delay(time_pH);                     //wait the correct amount of time for the circuit to complete its instruction.
      Wire.requestFrom(DEV_ID2, 20, 1); //call the circuit and request 20 bytes (this may be more than we need)
        pH_data[i] = in_char;            //load this byte into our array.
      Serial.println(pH_data);          //print the data.
      delay(delay_time);
      Wire.requestFrom(DEV_ID3, 48, 1);
      code = Wire.read();
        i += 1;
        if (in_char == 0) {
          i = 0;
      code = Wire.read();
        case 254:
        case 255:
  byte flag = 0;
  byte i = 0;
      flag = 1;
