Measuring a flowrate, provided by 20mV pulses via AnalogIn
Hey Everyone,
as I'm about to measure my fuel-oil consumption, I bout a flowmeter.
This device provides about 10.000 imp./L when a flow rate of 0.025 - 2,5L/min is flowing. (This is the specified working range)
The pump-flowrate will be about 2-4L/h, which equals roughly 0,05L/min. So to measure, this would be 500 imp./min = 8,3 imp./s.
The pulses will be a 20mV signal, so I guess I need to connect it to the analog-in.
I tried it with a simple voltage output-sketch, and when it runs, I can see the reaction. The signal is at 0 when not rotating and goes to approx. 1-10, while the max. in the program I'm using is 1023 (10bit)
Here comes my problem:
How can I count this? I have not found anything for counting analogIn etc. Best regards, Maeffjus
You write code. It may look like
count++
You need to connect it to an amplifier, first. That signal will produce noise as far as the analog pins are concerned.
How can you count what? It seems to me that you want to count peaks. Well, first you need to find them. Google peak detection.
I'm out - the sensor did not even move when connected between the fuel oil tank and my heater. (Too little flow) Now I'm back to measuring with ultrasonic. When these arrive I will have to ask a lot about RS485 ;-) Regards, Maeffjus
Isn’t the burn rate fairly constant? It might be sufficient to time how long the burner is running to get a very close approximation of how much fuel is used. Put a line-voltage relay’s coil across the burner motor wires and use any of the relay contacts as a switch input to the Arduino. The Arduino can then easily sense when the burner is ON and OFF.
After you gather data for a half a tank or so you can compare your Arduino’s total burn time to the amount of fuel used in the tank to get a ml/min burn rate. Then you can convert burn time to liters.
That don't sound right, is it an open collector output from the sensor? Can you post a link to the sensor datasheet?
