Measuring a very fine wire with 10 µm precision
Thank you all for the answers.
My idea is to spool the wire exactly from one "lip" of the coil former to the other without any gaps. To solve the gap problem, lag works quite nicely. However, even if I measure the wire at several place and use that measurement any slight variation of the wire creates problems when it comes to calculating the amount of turns required (coil_length / wire_diameter). Over several thousands of turns even a variation of 0.001mm can amount to a gross gap. I was thinking that actively measuring the wire diameter for discrepancies would allow me to set the number of turns as a "moving target" during coiling so that the wire ends up exactly at the lip.
Perhaps I should be looking for a strategy/some kind of sensor that would be able to sense the presence of the wire when it reaches the coil lip instead of trying to measure the error? I want to minimize contact with the wire as it is coated with a fine layer of plastic (that I want to avoid stripping away).
How much variation is in the wire itself or the thickness of the insulating coating? How would this effect your project?
Goodluck,
jolphil
Are you trying to determine when a single layer of the coil has reached the far lip (and presumably needs to reverse to form a new layer), or when the layers of the coil have built up to the required outside diameter?
jolphil:
Goodluck,
jolphil
There is enough variation that taking several 0.001 precision measurements of the wire and using an average to calculate the amount of turns (coil_length / wire_diameter) yields inconsistent results. This can be due to the coating or other imperfection in the wire. This affects my project because I aim to make "multi-layer" coils and so I need to be able to stop exactly at the "lip" of the coil before reversing the direction of coiling.
If there is still a gap left between the wire and the coil lip, the reversal is problematic.
PeterH:
Yes;
I am trying to determine when a single layer of the coil has reached the far lip in order to properly reverse to form a new layer.
Stopping exactly on the far lip is required in order to properly reverse to the new layer and keep a tight packing without overlaps. When using a single average value for the wiere diameter, the accumulation of error over thousands of turns yields inconsistent results (i.e. the wire will stop before or after (spool unto itself) the far lip).
Basically, I am trying to find a way that will guarantee that the wire will always stop exactly at the far lip.
But unless the error was such that you had accumulated an integral number of wire thicknesses, that's not going to help.
Let's say it nominally holds 100 turns along the length. You measure that the wire is a bit thicker say, and by the time you get to where the 99th row would be, you think Oops, we've actually got 99.5 thicknesses. So what do you do? You can't fit another full turn into 0.5 of turn's gap, so you can't stop exactly on the far lip anyway... not in terms of wire widths.... so you reverse with half a wire width gap.
(That made sense to me in my head- might need a drawing to describe it but I cba doing that right now.)
Point is, I'm pretty sure there are best-practices for doing this commercially, and I don't think this is one of them with all due respect.
Boots507:
By measuring the wire thickness you could estimate the number of turns needed but I don't see how you'd ever get it exact.
I don't know whether it would be practical with wire that fine, but I wonder whether it might be more effective to detect the outer diameter change as the wire hits the lip at the end of the former, rather than try to predict when it will hit? If you used a floating pulley, you'd need to detect a movement equal to the thickness of your wire.
Boots, me thinks you're approaching this problem from the wrong direction.
Also, copper wires are force-drawn/pulled through a die at the factory, so they're pretty much the same diameter. Being able to detect variations of 0.001mm won't do squat to what you're trying to accomplish. It's immaterial.
I would concentrate my efforts on a mechanism for consistent tight winding, and accurate inductance values. If the wire ends in the middle of the coil (to achieve the correct inductance value), then so be it. Tape the wire at that spot, then run a few inches of flying lead wires, solder to the transformer terminals (or solder to a thicker flying lead wire). The wire doesnt necessarily have to end at the lip. -- thats how commercial audio transformer makers do it.
EDIT:
The core you use for your transformer will also have variations in their permeability. Even if you got your wire diameter detector correct (which I doubt), the next core you grab may be slightly off, and the next transformer you wind will not end up exactly at the lip (to achieve the correct inductance value)... so now what? You're back to where you started. You cannot predict where the wire should end because you'd have variations in the size and permeability of your core (if you care about getting the right inductance value).
I try to go back to the original question, how can I measure the wire with that precision ?
I don't think there is a practical mechanical way to achieve such precision.
So what about a digital microscope ?
well I don't know your budget (there are cheaper options), but the idea is to "enlarge" the wire, and measure the variation of the image. I mean, measure the difference of light transmittance .....
Maybe it's just an weird idea but I have no other.
Lets try to design the sensor you need,
design 1: - conductive wire
imagine a V shaped sensor that guides the wire.
depending on the thickness of the wire it will be higher or lower in the V shape
make the sides of the V of a conducting material with known (relative to wire high) resistance
The place of the wire will change the resistance of the V as the level where the wire is short-cuts the current.
design 2: - shadow
place a laser let the wire move in front of it.
@10uM a known amount of light will pass above and below the wire
make that minimal @12 uM - you need mirrors at exact angles
place a TSL235 in the laser bundle - this convert intensity to frequency.
when the diameter varies the intensity will vary
laser >-------------------- | - - - - - - [sensor]
now shoot!
Best option is to use an optical microscope. "Seeing" 1um is not hard at all. Get a decent CCD camera from Pixelink or Basler or any other brand with a 1" sensor and a pixel size of 2-3um. You'll also need a microscope and some basic image processing to automatically identify the wire (easy when looking for a straigth line on a uniform backgound)
It shouldn't cost more than $1000.
Hello, I think the weapon of your choice would be a so called 'micrometer' :stuck_out_tongue: Micrometer - Wikipedia
Plus: If you want to measure in such small dimensions, be aware of the fact that even the warmth of your hand and also the atmosphere around the wire has an impact on the extension of the wire. I'm going with vasquo's oppinion.
//edit: With what I want to say: If you're going to measure a wire by applying voltage, it will expand slightly due to warming up slightly (electrons colliding inside the copper), so I assume you can basically forget that...
osterchrisi:
No I don't think so, resolution and precision are not enough
maybe something like this ...
http://www.keyence.com/services/download.php?file=im6000_ka.pdf&fs=IM-6000&ws=none&img=oc_cmm_lp.jpg&layout=d2d&lil_id=1309212783&lil_ly=aln-l_tfsz-20_dfsz-16&aw=gagooglekaim899063b&gclid=CLC97ta9-rQCFUFb3god9Q8AvQ
but again, the budget is ?
I think szangvil and robtillaart have the point.
robtillaart:
You do know the wire is insulated (and not BARE). It's a "magnet" wire, the kind used to make coils. If you strip the insulation just so you can measure it's resistance, well, you just made your coil useless.
I think the OP needs to visit an audio transformer manufacturer so he can see how it's done. These guys don't measure their wire diameters to micron precision or use lasers or microscopes as they wind. But they do measure their inductance and DC resistance values. They don't care where the loop ends. Overwind a few extra turns, measure, unwind, measure, tap it, then tape it. Done.
Have you guys seen the insides of an audio transformer?
robtillaart:
I don't think that would work, because the wire is insulated. Using a camera and microscope seems like the most likely approach to me, but the other option would be to create a rolling version of a standard wire gauge (using a pair of opposed precision ground rollers with a slight taper, and angled so that they tended to pull the wire away from the narrow end of the V as it rolled between them). The height of the wire in the gauge would tell you the thickness of the wire to whatever precision you wanted, as long as your rollers were sufficiently accurate.
For initial optical testing, there seems to be inexpensive microscope cams up to advertised 800x power.
https://www.google.com/search?q=webcam+microscope&num=100&hl=en&lr=&tbo=d&source=lnms&tbm=shop&sa=X&ei=ndz9UP6aE-iD0QH6oIHoDw&ved=0CAwQ_AUoAA&biw=1173&bih=642
If we're winding inductors here, the inductance of a coil is proportional to the number of turns squared. If the aim is to produce an inductor with a specific inductance, then the number of turns would be the important parameter to control. There should be little effect if things get scrambled a bit at the ends.
Thinking further, the concept of measuring one parameter (wire diameter) and calculating the number of turns based on that is flawed. It is an open-loop system and doesn't take a myriad of other variables into account, therefore the calculation will never be perfect. What if the next batch of forms are slightly different in size? What if the standard deviation of same changes? Etc. etc.
A better approach would be to somehow sense when the winding reaches the end of the form rather than calculate it. This is a feedback mechanism that allows for all those other variables (including the ones we haven't thought of) and doesn't require constant measurements of the input (wire). Maybe it's the angle of the wire from the supply point, or maybe tension, etc.
I can buy any number of products that are neatly wound on their spools, e.g. string, thread, wire, solder, etc. There must be some fairly common mechanism to do this that you just need to discover. The wheel has already been invented here. The question I would ask is how are all these other products wound on their spools neatly, not how can I invent an original contraption to do it.
Hello all, I want to thank you for your participation in this thread so far. My name is Dan and am Boots507's colleague. I would like to better explain our motivation for creating "perfectly" wound coils. In Non-Destructive Testing (eddy-current), electromagnetic coils interact with conducting samples via induction processes. Theoretical models can be compared to experimentally acquired data in order to infer geometrical and electrical properties of the sample. However, this approach requires integrating the electric filed over the cross-section of the coil. Thus, these solutions are highly sensitive to the quality of the coil. More explicitly, they assume that the coil has a uniform turn density and a rectangular cross-section. Therefore, we need a machine that creates ideally stacked coils.
An exact solution gives the theoretical inductance of a coil based on inner diameter, outer diameter and number of turns (uniform turn density and rectangular cross-section). Coils that I have wound very carefully by hand agree almost perfectly, whereas sloppily wound coils deviate significantly.
Hi Dan,
While in the past I have wound a few coils with AWG 44 wire,ever none needed that type of precision..My gut
feeling is this may be almost impossible . I guess I do not fully understand your problem but just to throw this out.
Why can you not wind your coil as precise as you can in practice, and later in some uniform test, add or subtract some correction factor so that each coil results in a uniform result.All the previous posts pointed out the pitfalls and problems in trying to get absolute winding results..
Anyway,
Goodluck
jolphil
