I have come across this sketch on the internet and i was wondering how the creator has measured the amps section at the bottom
const int sampleWindow = 50; // Sample window width in mS (50 mS = 20Hz)
// this is to pick up frequencies as low as 20Hz
unsigned int sample;
unsigned long previousMillis = 0;
const long interval = 1000;
unsigned long startMillis= millis(); // Start of sample window
unsigned int peakToPeak = 0; // peak-to-peak level
unsigned int signalMax = 0;
unsigned int signalMin = 1023;
// collect data for 50 mS
while (millis() - startMillis < sampleWindow)
sample = analogRead(A0);
if (sample < 1023) // toss out spurious readings
if (sample > signalMax)
signalMax = sample; // save just the max levels
else if (sample < signalMin)
signalMin = sample; // save just the min levels
peakToPeak = signalMax - signalMin; // max - min = peak-peak amplitude
double volts = (peakToPeak * 5.0) / 1023.0; // convert to volts
double watts = volts * 0.001; // volts times amps
Where have they got 0.001 from do you think? or how have they measured it?
double soundPower = 10.0 * log10(watts/10e-12);
double soundPressure = soundPower + (10.0 * log10(1.0/(4.0*PI*pow(2,2))));
In fact if anyone could break this down for me, that would be a great help
Out of context it's hard to know...
What are you trying to do?
I'm going to guess it's an "assumed value" because the programmer didn't know how to calculate dB from voltage/amplitude. And, I'm not even sure if that works... In general current is proportional to voltage (from Ohm's Law) so you can't have a fixed (or assumed) current unless the voltage is fixed.
P.S.
If you are trying to measure dB SPL (sound loudness in the air) you don't need voltage or current (amps). You just need an analog reading that correlates with loudness. And in any case, you'll need a real SLP meter to calibrate your readings.
DVDdoug:
Even then, it'd be:
watts = volts * volts * 0.001. // if R = (1/ 0.001)
The only way that it could be this is if the voltage was being generated by a constant current source:
watts = volts * 0.001. // if I is constant 0.001 A source
I think the OP needs to provide a link to where they got this code to see how (and if) this makes sense.
Its an adafruit sketch for a electret microphone that prints the voltage.
The addition to the code was from here: Ambient noise meter · GitHub
I just assumed this method of getting to dBSPL was correct.
From the voltage, what equation (or equations) could i use in order to convert it dBSPL?
Not in code, just the actual equations
mrears92:
Measuring Sound Levels | Adafruit Microphone Amplifier Breakout | Adafruit Learning System
Hmm...well, from adafruit's schematic and datasheet, I really can't see how the current would be fixed at 1mA.
I can't say that I'm familiar with condenser microphones, however. Maybe laserlemon knows something that isn't obvious from the schematic/datasheet. That 0.001 really does look like something that should be #defined at the top with a comment about where it came from.
