measuring angle accuretly
Can you measure an angle with IR sensor and arduino? My goal is to measure accurately measure how much a dc motor rotates. exact angle.if not..how can i do this?
Many people use a shaft encoder.
canucks:
Can you measure an angle with IR sensor and arduino? My goal is to measure accurately measure how much a dc motor rotates. exact angle.if not…how can i do this?
Look up ‘absolute encoder’. That’s one option.
Another option is ‘incremental encoder’.
A dc motor without a gearbox? My robot car came with two dc motors with integrated gearboxes. I bet you mean something similar. Along with the car I got these encoder discs with 24 slots. If I attach the wheel to the motor shaft and a led and an ldr, I can count pulses while the motor revolves. 15 degrees per pulse.
You could use an AS5040, it is a 10 bit absolute hall effect encoder. You put a special sort of magnet on the end of the shaft and have this chip mounted a few mm in front of it. Then you get a reading of the angle from it.
I used it for this project to measure the angles of these pendulums.
https://vimeo.com/95955945
canucks: Can you measure an angle with IR sensor and arduino? My goal is to measure accurately measure how much a dc motor rotates. exact angle.if not..how can i do this?
What is the motor and its shaft speed? Tom... :)
With resolvers.
https://www.google.co.th/search?biw=1707&bih=816&tbm=isch&sa=1&ei=5asWWufWGMXnvAS1-b2wBw&q=motor+resolvers&oq=motor+resolvers&gs_l=psy-ab.3...4302.6471.0.6876.12.8.0.0.0.0.207.775.0j4j1.5.0....0...1c.1.64.psy-ab..8.1.207...0i19k1.0.6NtWjv6ripw
