Measuring current drop
Hello,
I have an external circuit with 12V DC, having 2 stages of current circa 2mA and 1mA. I need to detect these states. What would you suggest to use INA219 or something simpler with shunt resistor.
The circuit is sensitive if I introduce too much of additional resistance, I assume extra 100ohms will be easily tolerated.
thanks,
Kernie
KernieBay:
please post complete circuit diagram and other info on this circuit.
What is that assumption based upon? If it is indeed fine for the circuit, I'd say problem solved. 1 mA = 0.1V, 2 mA = 0.2V. That you can detect with an analog pin already. Or add a 10x OpAmp stage and you have 1V and 2V.
Please see attached schematics.
It is an alarm circuit in my house which I am going to re-use to read motion sensors to control the lights.
Thanks!
If it’s in your house :
  1. Most alarm circuits use 4 or 6 wires ( 2 for tamper) . Can you not reuse those ?
  2. You could probably not bother with the tamper connection ?
You may have problems with your design if you multiple circuits - there must be a common 0v line.
I would first measure voltage on the two wires (in respect to alarm ground) with a DMM.
Voltage on one of the wires will depend on the three states of the two switches.
Easier to measure that than current.
The whole alarm system might be matrixed (keyboards/switches/etc).
Might have to use a scope to see that.
That could make it much harder to measure voltage or current.
Leo..
Hey guys, thanks for your replies. there are indeed additional free cables, however motion sensor doesn't have an additional free dry relay which I could use and then wired straight from Arduino.
I don't want to mess with the tamper, as it will require to change resistors at the Alarm Switchboard end.
No Motion/Motion there is a current drop from 1.43mA to 0.95mA, which is a bit weird given that resistance doubles from 4K7 to 9K4 and current doesn't halve. I measured the voltage at the switchboard panel where COM and Zone cables from the motion sensors are coming to and it is 6.7V.
Am I having the only option of using INA219 with shunt resistor of 1ohm (for bigger voltage drop, given low voltage, low current circuit) OR I can have a simpler schematics? I need to wire up 8 motion sensors in the end.
Many thanks
