Measuring Deep Sleep Current
Greeting,
I want to measure the current consumption of my STM32 in deep sleep. While I was looking for some examples about measuring very low current with dmm. I read something called brownout detetection. As I understood from some forums, I can not measure micro amper consumption in a microcontroller(DMM is set to uAmp mode). However I have to measure current consumption in deep sleep.
What can you suggest?
Thanks.
An internet search using the words "measuring MCU sleep currents".
Thanks for the answer.
People recomend using a resistor and measuring the voltage drop accros it, but I don't want to measure it with a resistor. My question is.
Is a good DMM able to measure MCU deep sleep current?
Yes.
I didn'know that.
Can you give an example?
Did you do a search on the internet using the words, "example measuring mcu deep sleep current"?
I could do internet search for you, for a fee, if you'd like.
Thanks for the answer. :yum:
I found out that in DMM's datasheets there is a section called burden voltage and it shows that the burden voltage in all ranges.
Let's say that my normal mode current is 200mA max and my deep sleep current is 5 uA. I can set the DMM in mA this will cause 0.36V in 200mA. If I power the mcu with 3.3V mcu will get only 2.94V. That is not a problem in my opinion. I can easily measure both normal mode and deep sleep at the same time.
Correct me if I am wrong. I am just making guesses that are based on some internet research.
You need a multimeter on uA and a bit of wire or a switch, details here;
Was my guess wrong?
Wow. It is very simple.
Thank you. :slight_smile:
