Measuring delay between two pulses using millis() and micros()
I am using Arduino Uno board for my project. What I am trying to do is to read the delay between two pulses. A set of pulses are generated using an Arduino Mega board. The delay between each pulse is set to 1 s (1000 ms).
In Arduino Uno I am using the attachinterrupt with the 3rd pin (ISR 1) to detect the rising edge of the pulses. When the first rising edge is detected I am keeping the time using micros() or millis() to a variable (t1) and when the 2nd rising edge is detected again I keep the time using micros() or millis() to another variable (t2).
After that took the difference between (t1 and t2) to get the delay time.
delay = t2 - t1;
Problem is,
When I was using millis() to keep the times for t1 and t2, I got delay values like 1005 ms, 1004 ms, etc. which are almost equal to 1000 ms delay (which is actual delay between the pulses).
When I was using micros() to do the same task the delay values I got are fluctuates a lot and after converting all those values to ms, those are not same as the values I got using millis(). The values I got using micros() are as follows.
658904 us
Can you please help to figure out what is happening in here.
Perhaps you should show us your sketch.
Hi there,
The code I am using is mentioned below.
#define RX 3
int unsigned flag1=0, flag2 = 0, flag3 = 0;
unsigned long t1 = 0, t2 = 0, t3 = 0;
void setup(){
pinMode(RX, INPUT);
digitalWrite(3,HIGH);
attachInterrupt(1, ISR1, RISING);
void loop(){
void ISR1(){
flag1++;
if(flag1==2){
t1 = micros();
detachInterrupt(digitalPinToInterrupt(3));
for (int i=0;i<800;i++) {
delay(1);
flag2 = 1;
if((flag2==1) &&(flag1==4)){
t2 = micros();
for(int i=0;i<800;i++){
delay(1);
flag3 = 1;
if((flag3==1) &&(flag1==6)){
t3 = micros();
delay(1);
Serial.print(t1);
Serial.print(" ");
Serial.print(t2);
Serial.print(" ");
Serial.print(t3);
Serial.print(" 1 ");
Serial.print(t2 - t1);
Serial.print(" 2 ");
Serial.println(t3 - t2);
flag1 = 0;
flag2 = 0;
flag3 = 0;
t1 = 0;
t2 = 0;
t3 = 0;
Please tell me the mistake I have done when taking the microseconds readings.
Change your ISR to make it much shorter. Perhaps
void ISR1() {
   pulseMicros = micros();
   newPulse = true;
and do all the other calculations in loop() with if (newPulse == true) {
...R
Time to read about interrupts:
Robin2:
Thank you very much for your help and it is working. :slight_smile: :slight_smile: :slight_smile: :slight_smile:
Dear All:
Thank you very much for your valuable ideas and advises. :slight_smile: :slight_smile: :slight_smile: :slight_smile: :slight_smile:
