I'm trying to turn on and off my dc motors with an IR receiver and it works. However, the dc motors are supposed to stop 20cm before an obstacle (Measuring distance using an ultrasonic sensor hc-sr04). The code I wrote only checks for the distance once when I press the On button. Any help is appreciated ![]()
Here is the code:
#include <IRremote.h>
#include <NewPing.h>
int IrReceiverPin = 52;
decode_results results;
IRrecv irrecv(IrReceiverPin);
int RECV_PIN = 52;// the pin where you connect the output pin of IR sensor
int distance = 0;
NewPing sensor (6 , 5, 100); // trig,echo,max distance in cm
pinMode(LED_BUILTIN, OUTPUT);
Serial.println("Starting IR-receiver...");
irrecv.enableIRIn();
Serial.println("IR-receiver active");
digitalWrite(LED_BUILTIN, LOW);
pinMode(8,OUTPUT);//Motor 1
pinMode(9,OUTPUT);//Motor 1
pinMode(12,OUTPUT);//Motor 2
pinMode(13,OUTPUT);//Motor 2
if (irrecv.decode(&results)) {
distance = sensor.ping_cm();
Serial.print("Distance is:");
Serial.println(sensor.ping_cm());
Serial.println(results.value, HEX);
irrecv.resume();
switch (results.value) {
case 0xFF02FD or 0xFFFFFFFF: // button ON
while (distance == 0)
digitalWrite(8, HIGH);
digitalWrite(9,LOW);
digitalWrite(12,HIGH);
digitalWrite(13,LOW);
while (distance <= 20)
digitalWrite(8,LOW);
digitalWrite(12,LOW);
case 0xFF9867 : // button OFF
