Measuring engine rpm and displaying on LED bargrap
Ok, what im trying to do is measure engine rpm, I have 7 leds. Each led representing 1000rpm.
So for 1000rpm, 1 led is on, 2000rpm 2 leds on etc.
And at 6150rpm the last led will start flashing. Rev limit been at 6250 rpm. Maybe the last led could blink faster as I get closer to 6250 rpm ?
I adapted the code from the PC fan speed tutorial in the playground using interrupts.
By editing this:
 rpm = 20*1000/(millis() - timeold)*rpmcount;
I can change it to calculate rpm for a 6cyl 4 stroke instead of a pc fan.
I then tryed a few different things using IF statements and Cases.
 volatile byte rpmcount;
 unsigned int rpm;
 unsigned long timeold;
 int rpmcheck;
 int si1 = 3;
 int si2 = 4;
 int si3 = 5;
 int si4 = 6;
 int si5 = 7;
 int si6 = 8;
 int si7 = 9;
 void rpm_check()
   rpmcount++;
attachInterrupt(0, rpm_check, RISING);
rpmcount = 0;
rpm = 0;
timeold = 0;
rpmcheck =0;
pinMode(si1, OUTPUT);
pinMode(si2, OUTPUT);
pinMode(si3, OUTPUT);
pinMode(si4, OUTPUT);
pinMode(si5, OUTPUT);
pinMode(si6, OUTPUT);
pinMode(si7, OUTPUT);
   digitalWrite(si1, HIGH);
   digitalWrite(si2, HIGH);
   digitalWrite(si3, HIGH);
   digitalWrite(si4, HIGH);
   digitalWrite(si5, HIGH);
   digitalWrite(si6, HIGH);
   digitalWrite(si7, HIGH);
     timeold = millis();
     rpmcount = 0;
     if (rpm < 1000)
         rpmcheck = 1;
       else if (rpm > 1000)
         rpmcheck = 2;
       else if (rpm > 2000)
         rpmcheck = 3;
       else if (rpm > 3000)
         rpmcheck = 4;
       else if (rpm > 4000)
         rpmcheck = 5;
       else if (rpm > 5000)
         rpmcheck = 6;
       else if (rpm > 6000)
         rpmcheck = 7;
       else if (rpm > 6200)
         rpmcheck = 8;
       switch (rpmcheck) {
         case 1: // Less than 1000 rpm
         case 2: // Over 1000 rpm
           digitalWrite(si1, LOW);
         case 3: // Over 2000 rpm
           digitalWrite(si2, LOW);
          case 4: // Over 3000 rpm
           digitalWrite(si3, LOW);
          case 5: // Over 4000 rpm
           digitalWrite(si4, LOW);
          case 6: // Over 5000 rpm
           digitalWrite(si5, LOW);
          case 7: //Over 6000 rpm
           digitalWrite(si6, LOW);
          case 8: // Over 6200 rpm
          digitalWrite(si7, LOW);
The led pins are si1, si2, si3 etc.
They are pulled low because of the way they are wired. ie, digitalWrite(si7, LOW); will turn the led 7 on.
I havent yet had it measuring rpm (still having hardware troubles).
I also tryed some code using only IF statements ie.
If (rpm > 1000)
etc etc.
At the start of the code i just set a varible called rpm and set it to 2000rpm to test it (since i dont have hardware side sorted out yet)
But it lit 3 leds instead of 2.
And 4 leds instead of 3 etc, basically just indicated 1000rpm higher than acutal.
Anyway im sure there is a quicker more efficient way of doing what I want to do, I just cant think of it.
Any input would be greatly appreciated.
I quickly made a program that showed what I would like the leds to do and videoed it.
http://orac.e30nz.com/DSCF2188.AVI
