I am doing a project and setup a wheatstone bridge with a photoresistor as on of the sensors for the bridge. I cant figure out a code to measure the frequency of a light flashing on and off on the photoresistor. I currently have the Voltage input on the A4 pin on the Arduino nano.
// the setup routine runs once when you press reset:
// initialize serial communication at 9600 bits per second:
pinMode(0, OUTPUT);
// the loop routine runs over and over again forever:
// read the input on analog pin 0:
float analogValue = analogRead(A4);
// Convert the analog reading (which goes from 0 - 1023) to a voltage (0 - 5V):
float voltage = map(analogValue, 0, 1023, 0, 5);
analogWrite(0, voltage);
// print out the value you read:
Serial.println("Analog: ");
Serial.print(analogValue);
Serial.print(" Voltage: ");
Serial.print(voltage);
this code only measures voltage.
I am having trouble coming up with a code instead of voltage it is frequency that is measured.
Your circuit is wrong, you short one branch of bridge with yellow jumper, you need separate battery for bridge, what frequency you are talking about, this is DC or AC bridge ?
This is an AC bridge, plus if i run the code that i have now it works perfectly fine. It just gives me the reading in bits due to the analog. The Yellow jumper is needed for the plotter to read due to being connected to ground.
To measure frequency, you need to measure the time between points where the value of the waveform repeats. Or, you can count repeats during a given time period.
Google "arduino frequency measurement" for some ideas.
It is not clear, on the picture you have left side of the bridge connected to +5V and right side to ground = DC supply to the bridge = DC bridge. Resistor under photoresistor - left side through yellow jumper to ground, right side trough orange jumper also to ground = that is a miracle that the bridge is working.
Bridges also need to be balanced ......
your circuit is working as a voltage divider not as a bridge, two resistors on the bottom are useless
You can’t use float in the map function, only integers .
You should use integers throughout , you can’t write a float to analog , it will only set part of the number if it works at all .
Bear in mind a LDR has a limited frequency response
