Measuring how long a button was pressed
How can I measure the time between when a button was pressed and when it was released? I have all the code working for button pressing etc., but I want a certain action when the button is held for 3 seconds.
Thanks!
When the button goes HIGH/LOW record what millis() is.
When the button goes LOW/HIGH record what millis() is.
Then take the difference between the two recorded values.
Show us what you have.
Attach your code using the </> icon on the left side of the posting menu.
Put your sketch between the code tags [code]Paste your sketch here[/code]
So . . . . the button is going to have to be pressed for precisely 3 seconds? Like, 3.000 seconds precise? :slight_smile:
unsigned long buttonPressedAt = 0;
const int BUTTON = 3;
bool buttonReleased = false;
byte buttonPrevState = 0;
 pinMode(BUTTON,INPUT);
  int state = digitalRead(BUTTON);
  if (state != buttonPrevState) {
    if (state == HIGH) {
      buttonPressedAt = millis();
    else {
      buttonReleased = true;
    buttonPrevState=state;
  if (buttonReleased == true) {
    after3Sec();
    buttonReleased=false;
void after3Sec() {
  long diff = millis()-buttonPressedAt;
  if (diff>3000) {
    //do action for 3 sec button press
Not tested, modified the code for your requirement.
Wrote this for another post, check this post cant solve this one out! - #11 by sarouje - Programming Questions - Arduino Forum
INTP:
correction, 3000 milli sec :slight_smile:
