I've adapted this code: Elimeléc's Arduino Projects: Measure RPMs Arduino to read six hall sensors (http://hamlin.com/product-detail.cfm?productid=78)
Every second, it adds up all the values and converts the total to a range of 1-5.
Depending on the outcome, one of five relays is triggered.
Here's a quick video I made of my test setup: www.youtube.com/watch?v=-P-lzth5u-o
When the sensors aren't triggered, everything runs fine (I've got it sitting on my desk for about half an hour now, without any problems) But when the sensors are triggered, I'm experiencing random crashes (the code will just stop and I need to reset the arduino)
I've already tried uncommenting/removing the serialPrints, but that doesn't make a difference.
Any help would be really apreciated
// Source: http://elimelecsarduinoprojects.blogspot.nl/2013/06/measure-rpms-arduino.html
// read RPM
volatile int rpmcount1 = 0;//see http://arduino.cc/en/Reference/Volatile
volatile int rpmcount2 = 0;
volatile int rpmcount3 = 0;
volatile int rpmcount4 = 0;
volatile int rpmcount5 = 0;
volatile int rpmcount6 = 0;
int rpm1 = 0;
int rpm2 = 0;
int rpm3 = 0;
int rpm4 = 0;
int rpm5 = 0;
int rpm6 = 0;
unsigned long lastmillis = 0;
int averageRpm;
int stageOld = 1;
int stageNew = 1;
int relayPin1 = 8;
int relayPin2 = 9;
int relayPin3 = 10;
int relayPin4 = 11;
int relayPin5 = 12;
void setup(){
attachInterrupt(0, hallSensor1, FALLING);//interrupt 0 is on pin 2.
attachInterrupt(1, hallSensor2, FALLING);//interrupt 1 is on pin 3.
attachInterrupt(2, hallSensor3, FALLING);//interrupt 2 is on pin 18.
attachInterrupt(3, hallSensor4, FALLING);//interrupt 3 is on pin 19.
attachInterrupt(4, hallSensor5, FALLING);//interrupt 4 is on pin 20.
attachInterrupt(5, hallSensor6, FALLING);//interrupt 5 is on pin 21.
pinMode (relayPin1, OUTPUT);
pinMode (relayPin2, OUTPUT);
pinMode (relayPin3, OUTPUT);
pinMode (relayPin4, OUTPUT);
pinMode (relayPin5, OUTPUT);
digitalWrite (relayPin1, HIGH);
digitalWrite (relayPin2, HIGH);
digitalWrite (relayPin3, HIGH);
digitalWrite (relayPin4, HIGH);
digitalWrite (relayPin5, HIGH);
digitalWrite (relayPin1, LOW);
delay (100);
void loop(){
if (millis() - lastmillis == 1000){ //Uptade every one second, this will be equal to reading frecuency (Hz).
detachInterrupt(0); // Disable interrupt when calculating
detachInterrupt(1);
detachInterrupt(2);
detachInterrupt(3);
detachInterrupt(4);
detachInterrupt(5);
rpm1 = rpmcount1 * 30; // Convert frecuency to RPM, note: this works for one interruption per full rotation. For two interrups per full rotation use rpmcount * 30.
rpm2 = rpmcount2 * 30;
rpm3 = rpmcount3 * 30;
rpm4 = rpmcount4 * 30;
rpm5 = rpmcount5 * 30;
rpm6 = rpmcount6 * 30;
averageRpm =((rpm1 + rpm2 + rpm3 + rpm4 + rpm5 + rpm6) / 6);
if (averageRpm >= 0 && averageRpm < 40) {
stageNew = 1;
else if (averageRpm >= 40 && averageRpm < 80) {
stageNew = 2;
else if (averageRpm >= 80 && averageRpm < 120) {
stageNew = 3;
else if (averageRpm >= 120 && averageRpm < 160) {
stageNew = 4;
else if (averageRpm >= 160) {
stageNew = 5;
switch (stageNew) {
case 1:
if (stageOld == 1) {
else {
delay (100);
stageOld = stageNew;
case 2:
if (stageOld == 2) {
else {
digitalWrite (relayPin2, LOW);
delay (100);
case 3:
if (stageOld == 3) {
else {
digitalWrite (relayPin3, LOW);
delay (100);
case 4:
if (stageOld == 4) {
else {
digitalWrite (relayPin4, LOW);
delay (100);
case 5:
if (stageOld == 5) {
else {
digitalWrite (relayPin5, LOW);
delay (100);
Serial.print("RPM1 =\t"); //print the word "RPM" and tab.
Serial.print(rpm1); // print the rpm value.
Serial.print("\t Hz=\t"); //print the word "Hz".
Serial.println(rpmcount1); //print revolutions per second or Hz. And print new line or enter.
Serial.print("RPM2 =\t"); //print the word "RPM" and tab.
Serial.print(rpm2); // print the rpm value.
Serial.println(rpmcount2); //print revolutions per second or Hz. And print new line or enter.
Serial.print("RPM3 =\t"); //print the word "RPM" and tab.
Serial.print(rpm3); // print the rpm value.
Serial.println(rpmcount3); //print revolutions per second or Hz. And print new line or enter.
Serial.print("RPM4 =\t"); //print the word "RPM" and tab.
Serial.print(rpm4); // print the rpm value.
Serial.println(rpmcount4); //print revolutions per second or Hz. And print new line or enter.
Serial.print("RPM5 =\t"); //print the word "RPM" and tab.
Serial.print(rpm5); // print the rpm value.
Serial.println(rpmcount5); //print revolutions per second or Hz. And print new line or enter.
Serial.print("RPM6 =\t"); //print the word "RPM" and tab.
Serial.print(rpm6); // print the rpm value.
Serial.println(rpmcount6); //print revolutions per second or Hz. And print new line or enter.
Serial.print("Stage=\t"); //print the word "Stage".
Serial.println(stageOld); //print stage. And print new line or enter.
rpmcount1 = 0; // Restart the RPM counter
rpmcount2 = 0;
rpmcount3 = 0;
rpmcount4 = 0;
rpmcount5 = 0;
rpmcount6 = 0;
lastmillis = millis(); // Uptade lastmillis
attachInterrupt(0, hallSensor1, FALLING); //enable interrupt
void hallSensor1(){ //this code will be executed every time the interrupt 0 (pin2) gets low.
rpmcount1++;
void hallSensor2(){ // this code will be executed every time the interrupt 1 (pin3) gets low.
rpmcount2++;
void hallSensor3(){ // this code will be executed every time the interrupt 2 (pin18) gets low.
rpmcount3++;
void hallSensor4(){ // this code will be executed every time the interrupt 3 (pin19) gets low.
rpmcount4++;
void hallSensor5(){ // this code will be executed every time the interrupt 4 (pin20) gets low.
rpmcount5++;
void hallSensor6(){ // this code will be executed every time the interrupt 5 (pin21) gets low.
rpmcount6++;
