Measuring negative DC voltage (0 to -2.5) for monitoring electrometer ion gage
My end goal is to create a digital read-out and interlock logic circuit of pressure as a function of voltage from an auxiliary signal of an electrometer ion gauge. Here the arduino needs to measure a DC voltage from an ion gage controller accessory cable in which the electrometer signal (0 to -2.5 V, 2Kohm impedance) corresponds to meter information in the controller, a pressure between 10^-8 and 10-4 Torr.
My issue is that the arduino uno does not handle negative voltage. I'm open to suggestions on how to obtain this signal.
I've attached a relevant .pdf section of the ion gauge controller manual that describes the signal I'd like to collect with the arduino (pins 2 & 9, signal & ground respectivly).
Accessory_pin_Granville_Phillips_270.pdf (17.4 KB)
I can only see page 3 of 6. Do you have the entire document. From this restricted glympse, I get the impression that you may have access to -5v
If so you could connect this to your arduino GND then make your readings relative to this. (assuming your arduino and the other equipment have independent power sources)
I would use an inverting op amp powered by +/- 5V rails.
My first thought was to ground the negative signal to the arduino and measure the controller's ground as you've suggested KenF. I didn't know if this would damage the arduino but I'll try it after the inverting op-amp method. Thanks Grumpy_Mike and KenF. I'll follow up when I have the solution. Best.
Not as such but if you plug in your laptop while it is connected then there is potential for disaster.
