I'd like to be able to measure the deflection of a pendulum assembly.
The assembly won't move more than a few centimeters in any direction, but the force that moves it will be very slight, so whatever mechanism I attach to it to measure the deflection will have to be light, if it has too much resistance then the pendulum will stop moving. I guess I'm looking at some sort of linear encoder.
The total movement of the pendulum would be no more than 10 cm end-to-end, and I'm hoping to get a resolution of 1/2 a millimeter or better.
I had considered attaching the pendulum to a large linear potentiometer and using it as a simple voltage divider to get the position, but I think the resistance of the pot. would restrict the movement of the pendulum.
I'm now thinking I'll have to use some sort of optical method, any suggestions?
Cheers
