Measuring strain
Hi
I really need help with the project I'm working on. I'm supposed to visualize digitally the strain of a loaded beam. I've already installed strain gauges in a full bridge arrangement
For the circuit part I was given a SEN-13230 Load Cell Amplifier and an Arduino Uno, along with a Load Cell to test all codes before i move on to the beam, but I'm clueless about how can I make this work. Especially because I've never worked before with arduino board.
I've found a library with some codes thay seems to be compatible with the load cell and the amplifier but I get no results at all. Error after errors, with some "0.00" measurements in between (which make me think that even my circuit makes no sense), I'm totally stuck
Any help will be appreciated
could you post a circuit diagram and your code - then we may be able to help...
regards
Allan
