Measuring the external temperature of an induction motor
Are sensors such as the DS18B20 affected by the stray magnetic field you would get if attached to the exterior aluminium housing of a 1hp motor?
My guess is that the sensor would be 1 or 2 cm from the actual winding.
Mike
I don't THINK so.. The DS18B20 is running on 5V and if you twist the signal wires together they would not pick up a lot of noise. If you use a "waterproof" DS18B20 then the chip is inside a stainless steel tube and has more protection. See This Page for info. The waterproof sensors are shown HERE
mikb55:
Mike
No, its non-magnetic, its just a piece of silicon in epoxy. Just don't make the mistake of attaching the
sensor ground to the housing - sensors should only be grounded at the Arduino end, to avoid any chance of
a ground loop.
