Measuring the voltage of the power supply with MEGA2560
Hello everyone,
I have a remote control powered by batteries delivering a voltage between 3.6 up to 5V. A Pololu stepup converter is used to generate a stable 9V for Vin of the MEGA2560. A Nextion 4.3" display(IN = 80 mA continous) is connected with the 5V GND of the MEGA2560 and a HC12 module (IH = 80 mA max) with 3.3V GND. Everything works properly. Now I want to display the charge status of the battery on the Nextion display. As test I flashed the following sketch
int analogInput = 1;
int refresh = 1000;
int vout = 0;
int vin = 0;
int value = 0;
float R1 = 0.0;    // R1
float R2 = 1.0;     // R2
void setup(){
  pinMode(analogInput, INPUT);
void loop(){
  Serial.println( readVcc(), DEC );
  value = analogRead(analogInput);
  if (value >= 1023) {
    Serial.println("Maximum value reached!!");
    delay(refresh);
    return;
  else if (value <= 0) {
    Serial.println("No voltage!!");
    delay(refresh);
    return;
  vout = (value * readVcc() / 1000) / 1024.0;
  vin = vout / (R2/(R1+R2));
  Serial.print(vin);
  Serial.println(" volt");
  delay(refresh);
long readVcc() {
  long result;
  ADMUX = _BV(REFS0) | _BV(MUX3) | _BV(MUX2) | _BV(MUX1);
  delay(2);
  ADCSRA |= _BV(ADSC);
  while (bit_is_set(ADCSRA,ADSC));
  result = ADCL;
  result |= ADCH<<8;
  result = 1126400L / result;
  return result;
I put the battery + to analogue input 1. I checked by measurement that the GNDs of the step up converter are connected.
As example result I get the following from the serial monitor
187733
0 volt
160914
522 volt
563200
209 volt
375466
209 volt
281600
523 volt
281600
523 volt
563200
348 volt
1101
149 volt
225280
261 volt
281600
174 volt
-1
174 volt
281600
174 volt
1101
209 volt
When measuring the battery voltage directly with a voltmeter I get a stable 4.57 V. This does not comply with the monitor results which seem to be more randomly generated. Now I am confused :confused: if it is a programming or a circuit issue. Can someone help me out? :slight_smile:
PS. The resistors R1 and R2 are left out since the voltage is below 5V and battery can be charged via USB supply.
