this is a code that i had only copied and can show the float switch on and off time. What i want to do is to only show the "float switch ON time". i have little experience in programming and if there is another approach i would want to know. thank you
unsigned long floatSwTimer;
bool floatSwState;
byte floatSw = 4; // Float switch pin, other side of switch to GND
pinMode(floatSw,INPUT_PULLUP);
if(digitalRead(floatSw) != floatSwState) // if they are different,
floatSwState ^= 1; // make them the same
if(floatSwState == false)
Serial.print("Float switch OFF time ");
Serial.print((millis() - floatSwTimer) / 1000);
Serial.print("\t");
Serial.println("Seconds");
Serial.print("Float switch ON time ");
Serial.print("\t");
floatSwTimer = millis(); // reset timer
Do you mean that you want to know the time the switch went from off to on or the amount of time it was on ? If the latter, is it cumulative time that you want or individual period times ?
UKHeliBob:
Basically, i want to know the amount of time it was off. sorry for the misconception. i want individual period of times.
When the switch goes from on to off you print a message. At that point save the value of millis() in a variable. When the switch goes from off to on you print a message. At that point subtract the previously saved time from the current value of millis() and you have the off time in milliseconds for the latest period.
A little maths and you can have it in any format you want ready to print or perhaps save to an SD card or send via a link to another device.
if (digitalRead(floatSw) != floatSwState) // if they are different,
if (floatSwState == false)
Serial.print("\t");
unsigned long offTime = millis();//save start time
Serial.print("\t");
unsigned long onTime = millis();
unsigned long offPeriod = offTime - onTime;
Serial.print("Off for ");
Serial.print(offPeriod);
Serial.println(" milliseconds");
Why doesn't the variable name contain Pin? If it did, the comment would be unnecessary. And, it would be obvious that the variable contained a pin number.
That variable contains a TIME, not a TIMER.
The digitalRead() function return HIGH or LOW. Why would you compare HIGH or LOW to false?
The inline declaration saves the overhead of actually having functions at runtime, but the rest of the code
will be more readable as it doesn't care about such details of active-low or high.
Is that actually true and if so, can you guarantee that it will stay that way ?
The Arduino functions cold, if they wished, be written to return say 123 for LOW and 124 for HIGH and they would still work if HIGH and LOW were defined appropriately when testing for HIGH and LOW. Such a change is unlikely to happen, but it could.
Not really. HIGH is defined as 1, and LOW is defined as 0. true and false also are defined as 1 and 0.
So, HIGH and true are defined to have the same value, but HIGH is not defined to be true.
Nothing in life is guaranteed, but the odds that true, false, HIGH, or LOW will be assigned different values are lower than the odds of Trump being re-elected.
