hello everyone, i have 2 of these voltage modules :
can i somehow combine them to be able to measure up to 50 volts or that wouldn't work?
or should i make a sperate voltage divider
You can make your own Voltage Divider, or put a resistor in series with the input (in series with the 30K resistor), or if you can solder surface-mount components you can change the resistor(s).
50V / (30000 + 7500) = 0,001333333 A or 1,33333 mA
7500 * 0,001333333 = 10V.
10 V damages the Arduino analog input.
See that the sensor is marked VCC < 25 V
yes i know that the maximum is 25 but what if i want to measure 50 ? should i make a new voltage divider or can i somehow utilize the 2 sensors the i have
what is the resistor value?
Use one of your dividers with a 39k resistor between it and the 50V+, give me a few minutes to make a drawing.
Change the 30K resistor with a 67.5K.
As there is no 67.5 K resistor, you will have to use a 68 K resistor.
With 68 K, the maximum value over the 7k5 resistor will be 4.96689 V
Common comercial resistors.
thank you so much!!!
Can you understand this drawing?
Thank you!
That is amazing thanks alot, that would save me so much hastle and so much time!
much appreciate your help
Any time, good luck.
