Measuring voltage and current from PWM solar controller
It sounds like you don't have much experience with solar panels. After some experimentation, you will learn that the open circuit panel voltage is nearly independent of illumination (above some minimum level of illumination), while the short circuit current flow is linearly proportional to the illumination intensity.
That is why solar panel voltage is of nearly zero interest when measuring the performance of a setup.
