Measuring Voltage of Battery
If the 5V of the Arduino is lower, the Arduino measures a higher voltage at the analog inputs.
That is because the 5V is the reference voltage.
If the USB is 4.8V, the calculation for the voltage in the Arduino should be adjusted for that to read the right voltage.
You can use the internal reference of 1.1V (asuming you have a Arduio Uno).
You have to use a voltage divider for the range of 0 to 1.1V.
The 1.1V is never exactly 1.1V, so I adjust my calculation for that. I also use the average of a few samples to reduce noise.
