Measuring voltage on A0 is creating noise on A1... WHY..??
I am trying to measure voltage with a voltage divider on A0 of arduino The voltage divider resistors are R1 = 2.2K & R2 = 820R
On the other side I am measuring Temperature with LM35 on A1..
Without any connection on the A0 of arduino the temperature is stable but as soon as I connect the voltage divider to the A0 there is fluctuation on the temperature... WHY...??
How to eliminate it..??
Read each input pin twice, & ignore the first reading. Gives the internal analog mux time to settle on the value you want.
CrossRoads:
How to do that…??
Can you please show me… :frowning:
value1 = analogRead(A0);
value2 = analogRead(A1);
just like it sounds, really.
WOW... thanks man... That really worked.... :) little crazy but its true... :)
