measuring wheel speed using inductive proximity sensor
Hello. I am trying to read speed from both front and rear wheels of my motorcycle. I am using an Arduino uno with a 16x2 lcd display to view results and two fotek pl-05l npn inductive sensors. Sensors are reading wheel spinning from 5 screws that each one has for the disk brake. The main idea is to calculate time between each screw and assuming that its 1/5 of wheel to calculate the km/h. So far I have managed to read wheel speeds and comparing them to my original motorcycle speedometer they are pretty close. The problem is that often I get no logical km/h for example while riding at stable 90km/h suddenly shows 50km/h for a while and after that I have 90km/h again. My sensors are supposed to work at 800hz which from my calculations are enough for over 300 km/h. Can anyone help to find a solution. Thanks’ in advance.
int rearpin = 7;
int frontpin = 8;
int rearpinvalue;
int frontpinvalue;
int lastrearpinvalue;
int countboltr;
int countboltf;
float rearstarttime;
float timepassedrear;
float rearoldmillis;
int lastfrontpinvalue;
float frontstarttime;
float timepassedfront;
float frontoldmillis;
float kmhrear,kmr,kmhfront,kmf;
#include <Wire.h>
#include <LCD.h>
#define I2C_ADDR    0x3F // <<----- Add your address here.  Find it from I2C Scanner
#define BACKLIGHT_PIN     3
#define En_pin  2
#define Rw_pin  1
#define Rs_pin  0
#define D4_pin  4
#define D5_pin  5
#define D6_pin  6
#define D7_pin  7
int n = 1;
LiquidCrystal_I2C  lcd(I2C_ADDR,En_pin,Rw_pin,Rs_pin,D4_pin,D5_pin,D6_pin,D7_pin);
lcd.begin (16,2); //  <<----- My LCD was 16x2
// Switch on the backlight
lcd.setBacklightPin(BACKLIGHT_PIN,POSITIVE);
lcd.setBacklight(HIGH);
lcd.home (); // go home
  pinMode(rearpin,INPUT_PULLUP);
  pinMode(frontpin,INPUT_PULLUP);
   lcd.setCursor (0,0);             // display welcome message on startup for 4 seconds and then clearing screen
  lcd.print("HAVE A NICE RIDE");
  lcd.setCursor (0,1);
  lcd.print("   DRIVE SAFE   ");
  delay(4000);
  lcd.print("                ");
  lcd.print("                ");
  rearpinvalue = digitalRead (rearpin);                     // reading value of rear sensor
if (rearpinvalue == HIGH && lastrearpinvalue == LOW)        // cheking if sensor has just left bolt limit which result changing from LOW to HIGH
 rearstarttime = millis();                                  // if yes store milliseconds from start time of arduino boot
 timepassedrear = (rearstarttime - rearoldmillis);          // and calculate time between previous valid sensor read
 rearoldmillis = rearstarttime;                             // storing milliseconds for the next time code run the same funtion
 kmhrear=(0,402*3600000)/timepassedrear;                    // calculating km/h for rear wheel depending wheel diameter,tire profile (17 inch wheel,55 profile in my case)
 kmr=(kmhrear/1000)/1000;
 countboltr = countboltr+1;                                 // every time running loop increasing a counter by one so every 20 bolt readings
 if (countboltr == 20)                                      // we print km/h of rear wheel on display.
 lcd.print("rear km ");
 lcd.print(kmr);
 countboltr = 0;                                            // after counter reach 20 we set it again to 0 to start counting again
 lastrearpinvalue=rearpinvalue;                             // setting value so we can make compare at next loop run
                                         // same for front wheel
  frontpinvalue = digitalRead (frontpin);                        // reading value of front sensor
if (frontpinvalue == HIGH && lastfrontpinvalue == LOW)           //cheking if sensor has just left bolt limit
 frontstarttime = millis();                                       // if yes store milliseconds from start time of arduino boot
 timepassedfront = (frontstarttime - frontoldmillis);             // and calculate time between previous valid sensor read
 frontoldmillis = frontstarttime;                                 // storing milliseconds for the next time code run the same funtion
 kmhfront=(0,376*3600000)/timepassedfront;                        // calculating km/h for front wheel depending wheel diameter,tire profile (17 inch wheel,70 profile in my case)
 kmf=(kmhfront/1000)/1000;
 countboltf = countboltf+1;                                       // every time running loop increasing a counter by one so every 20 bolt readings
 if (countboltf == 20)                                            // we print km/h of rear wheel on display.
 lcd.print("front km ");
 lcd.print(kmf);
 countboltf = 0;                                                  // after counter reach 20 we set it again to 0 to start counting again
 lastfrontpinvalue=frontpinvalue;                                 // setting value so we can make compare at next loop run
To remove spurious readings, you could average the readings over a number of readings and reject those that are not near the current average.
Weedpharma
nixtas:
I would recommend you change how your program is receiving the sensor data. You expect the loop() to catch the HIGH/LOW readings. It only looks for a microsecond during the digitalRead().
Think about using interrupts, with some sanity checks.
connect your signal to pin 2 and pin 3:
#define REARPIN 2
#define FRONTPIN 3
void setup(){
pinMode(REARPIN,INPUT_PULLUP);
pinMode(FRONTPIN,INPUT_PULLUP);
attachInterrupt(digitalPinToInterrupt(REARPIN),rearFunction,FALLING);
attachInterrupt(digitalPinToInterrupt(FRONTPIN),frontFunction,FALLING);
volatile unsigned long lastRearMillis; // millisecond counter lasttime rear sensor activated
volatile unsigned long rearDelta;      // current millisecond between activations
volatile unsigned long lastFrontMillis;
volatile unsigned long frontDelta;
void rearFunction(){
unsigned long tick=millis(); // current millisecond
rearDelta = tick - lastRearMillis;
lastRearMillis = tick;
void frontFunction(){
frontDelta = tick - lastFrontMillis;
lastFrontMillis = tick;
void loop(){
static unsigned long rearSpeed=0, frontSpeed=0; // initialize once at startup to zero
static unsigned long lastRearUpdate=0;
static unsigned long lastFrontUpdate=0;
// what is minimum speed?
if((rearDelta<MIMIMUMSPEED)&&(rearDelta>MAXIMUMSPEED)){ // valid speed
  //convert milliseconds between bolts to velocity
  if(millis()-lastRearUpdate>500){// update the screen every 1/2 second
    lastRearUpdate = millis();
   // code to update screen
if((frontDelta<MIMIMUMSPEED)&&(frontDelta>MAXIMUMSPEED)){ // valid speed
  if(millis()-lastFrontUpdate>500){// update the screen every 1/2 second
    lastFrontUpdate = millis();
Chuck.
weedpharma:
Weedpharma
the next step after reading correct wheel speeds is to compare them so if rear wheel loose traction and spins faster than front to cut ignition until regain traction.i think that rejecting out of range values will not help me in the future code.thank's
chucktodd:
#define REARPIN 2
#define FRONTPIN 3
void setup(){
void loop(){
Chuck.
thank’s for your reply.the screw head is about 1cm width and the gap between each screw is about 5 cm.so i believe that even a screw reading fails at one loop it will be at about same position for next code reading loop.is that right?do you believe that this values are not enough to get a correct high low reading.i want to understand why this is not working before i proceed to interrupt.
thank's for your reply.the screw head is about 1cm width and the gap between each screw is about 5 cm.so i believe that even a screw reading fails at one loop it will be at about same position for next code reading loop.is that right?do you believe that this values are not enough to get a correct high low reading.i want to understand why this is not working before i proceed to interrupt.
I agree with Chuck that you are probably missing pulses and that interrupts are the better way to go. If you miss a pulse, the reported speed will be 1/2.
Have you calculated the time each bolt head will be in front of the sensor? Have you benchmarked your loop speed with micros() time markers placed in the code?
You can speed up the loop by placing the lcd prints of the unchanging characters "front km" and "rear km" in setup so they are only printed once.
In your code, you measure the period for every bolt to bolt period, but report the data every 20. You might as well get in some averaging by timing the period for several bolt-bolt transitions.
Here is some example code which uses interrupts, and times the interval between multiple interrupts to determine rpm.
volatile byte  count = 0;
byte numCount = 8; //number of pulse intervals to measure
volatile unsigned long startTime;
volatile unsigned long endTime;
unsigned long copy_startTime;
unsigned long copy_endTime;
volatile boolean finishCount = false;
float period;
unsigned int rpm = 0;
  Serial.println("start...");
  attachInterrupt(digitalPinToInterrupt(3), isrCount, RISING);//interrupt on pin3
  if (finishCount == true)
    finishCount = false;//reset flag
    // disable interrupts, make protected copy of time values
    noInterrupts();
    copy_startTime = startTime;
    copy_endTime = endTime;
    count = 0;
    interrupts();
    period = (copy_endTime - copy_startTime) / 1000.0; //micros to millis
    //debug prints
    Serial.print(period); //total time for numCount
    Serial.print('\t');
    Serial.println(period/numCount);//time between individual pulses
       rpm = numCount * 12.0 * (1000.0/period);//five counts per revolution
    //rpm = numCount * 60.0 * (1000.0 / period);//one counts per revolution
    //rpm = numCount * 30.0 * (1000.0 / period);//two counts per revolution
    Serial.print("RPM = ");
    Serial.println(rpm);
void isrCount()
  if (count == 0)//first entry to isr
    startTime = micros();
  if (count == numCount)
    endTime = micros();
    finishCount = true;
  count++; //increment after test for numCount
The symptoms you describe sound like two different cycles ‘syncronizing’ (so that you miss some pulses), then going out of sync (and get them all!). The ‘loop()’ is the first cycle, the cycle of the wheel turning is the other.
What kind of pulse shaping, if any, do you do on the output of the sensor?
Depending on how short the pulse is, it could be that the loop randomly synchronizes its sampling of one of the pulses (on each turn of the wheel) outside of the time when your pulse is active. All of which is a complicated way of suggesting you are dropping events, as both cattledog and chuck previously suggested
I second (or third…) the suggestion of using interrupts. Also, on the Arduino, timer 1 can do a ‘capture input’ on an external event - perfect for this application.
Here’s how it might work:
Start the timer 1 ticking off of a system clock (or whatever…), with the ‘capture input’ feature of the timer enabled to detect the leading edge of the incoming pulse. When the pulse occurs, the capture-input feature will record the current clock value in the capture input register, and (optionally) trigger an interrupt. This is all done by hardware - the likelyhood of missing a pulse at your suggested speeds is close to zero.
The detection is is edge triggered, which should be more accurate than the sampling in the middle of the pulse you are doing now. On interrupt, the interrupt routine reads the capture input register, and by simple subtraction determines the number of clock pulses (interval) since the previous one.
To keep from missing an event, use an interrupt to determine when to take the reading from the capture register.
Hope this helps.
nixtas, interesting project. I am a bit concerned that you will not have enough resolution with using just the 5 bolts. Measure the circumference of your tire and divide it by 5. You will have a resolution of 10" plus or minus a few. You would have to get an error of two pulses minimum to react. The tire has already spun 20". On another note you may check your distance of you prox. from the bolt, it may be on the edge of its reading range. and using interrupts while counting is always a good idea.
1/ I take it you're getting clean pulses from your sensors - can you observe them with a scope?
2/ I've used pulseIn HIGH and LOW in a revcounter and obtained rock solid results...
regards
Allan.
Just looking at your code, if you just write code for one wheel only, does the problem occur?
Also these inductive sensors are industrial type, the pull_ups in the arduino are between 20K and 50K, these sensors are more used to 24V and 4K7 pullups.
So it would be worth putting a 4K7 resistor from the output of the sensor to 5V, rather than rely on the 20K or higher internal arduino pullup.
I would first only read and calculate for one wheel, get it right then see if the other will work in the same configuration.
Unfortunately FOTEK happen to be the brand of SSR that are sold on ebay where some have proven pretty shonky build quality.
Especially how you power the sensor as its minimum suppy is 10V.
Thanks… Tom… :slight_smile:
TomGeorge:
The power supply I use is 12 volt from my motorcycle battery,i tried to disable INPUT_PULLUP and use 10K external resistors but I had the same result.
Ok most of you suggested to go with interrupts so I tried today.Upload code and rolled my bike just to see if I get a count on display. It looked ok,....ok until I turned on my motorcycle then everything messed up, i was getting measurements without rolling, the more I throttling the more random km/h values appeared, seems like noise from electric parts affect my sensor inputs, with my previous code without interrupts there wasn't these effect. I guess there is a lot of work to do until I reach my goal.Can someone tell me at what voltage does falling or rising of interrupts takes place,if I have a 1volt for example noise will at falling back to 0 cause a FALLING trigger?
allanhurst:
regards
Allan.
can you give same more details of your project to give it a try.thanks
Hi Nixtas…
it sounds as if your getting electrical noise on your signal - you’ll have to sort that out first. If you have access to a scope this will be useful for identifying this. No software tricks help you here…
The relevant bit of my code is :
    pulselow = pulseIn( pulsepin, LOW,20000);  // measure pulsewidth
    pulsehigh = pulseIn( pulsepin, HIGH,20000);  // measure pulsewidth
    pulselen = pulselow + pulsehigh;    // total pulsewidth
    freq = 4000000 / pulselen ;          // gives freq in Hz * 4
             //and scale noting that typically 500hz = 2000rpm
and note it takes a signal from the activation pin of a conventional car alternator - actually on my daughter’s boat - and uses the attached signal conditioning - this has a high dynamic range - about 100mV p-p up to several volts - and isolates the arduino input from overvoltage.
regards
Allan
ps I then used the value to drive an aircored meter movement using sine and cosine lookup tables - which won’t be relevant to you…
edit… sorry - the input capacitor should be 1uF, not 1n as shown…
revsig.pdf (18.1 KB)
