Mechanical Engineer needing help!!!
You could do the ball raise/lower using a servo to push the ball up a tube when the weight of the ball on the tee shorts pin 4 to ground, and when the ball is removed pin 4 is unshorted and the servo moves the tee back down into the tube. code below.
//zoomkat servo button test 7-30-2011
#include <Servo.h>
int button1 = 4; //button pin, connect to ground to move servo
int press1 = 0;
Servo servo1;
  pinMode(button1, INPUT);
  servo1.attach(7);
  digitalWrite(4, HIGH); //enable pullups to make pin high
  press1 = digitalRead(button1);
  if (press1 == LOW)
    servo1.write(160);
  else {
    servo1.write(20);
