So I am working on a project. I am making a steering wheel and pedals for a racing simulator game. for steering its easy I can use mouse input to make a steering. but for brake and acceleration I want to use keyboard input. What i am thinking is to use a motor that will spin a disk with a sector of conductive tape on it and keyboard key wires sliding on it from center to outward as per pedals' movement , so when disk is spining it can modulate pwm and generate input by shorting the wires.
My question is will it work ?
what should be the rpm of motor ?
how short time stroke keyboard registers ?
I moved your topic to an appropriate forum category @xenomatrix.
In the future, please take some time to pick the forum category that best suits the subject of your topic. There is an "About the _____ category" topic at the top of each category that explains its purpose.
This is an important part of responsible forum usage, as explained in the "How to get the best out of this forum" guide. The guide contains a lot of other useful information. Please read it.
Thanks in advance for your cooperation.
The answer is "can you make it work"? Seems like an awful lot of mechanical stuff to build. Do you have a plan to keep the wires from bouncing around on the conductive tape?
No. You should not be thinking of building a racing simulator using tape.
Use a rotary encoder for steering.
For the accelerator and also for the brake, look at using two HX711 with springs to lower the maximum force.
