I am trying to build a robot that can be used for surveying people. With this, I am considering the use of mechanical push button that will act as the choices for my questions.
What I have been thinking is that I will use a transducer to transfer the mechanical signal from the push button and transmit it into the Arduino , then the Arduino will store it at MicroSD Module 2Gb for Arduino or SD card shield for Arduino V2.1.
Expected Problems and some Floating Questions:
I don't know how to convert the mechanical input into electrical pulse and the electrical pulse into tally.
What program to use to check the tally.
Can I use data base for this project? And what data base exactly?
Two pieces of wire stuck into the appropriate Arduino connectors can act as a switch so I don't understand why you are talking about a transducer. Any cheap pushbutton or toggle switch should be fine.
You won't be able to run any off-the-shelf database program on an Arduino Uno or Mega, and you may not need to if all that is needed is to store data into a file on an SD card for subsequent analysis on a PC.
If you really do need a database you will need to use a Yun or a Raspberry PI as they can run the Linux operating system. SQLite is an easy-to-use database for simple systems.
Presumably you are going to need some sort of screen display to present the questions to people. That can be done with an Arduino, but I suspect it would be very much easier with a Raspberry PI
