Why we have 2 arms for every motor arm?
I think that it should work with one arm and the down effector will still be parallel.
All designs available in internet use two arms but the only reason I can see is if their universal joins are
half spheres and they need a spring between them to hold the joins.
if we use regular ball joints / end rods / it should work with one arm per motor right?
Because you need at least 6 pivoted(*) support points to define the position of the head, use less
and the structure is floppy - its position is not completely constrained as an object has 6 degrees of
freedom and each link can only constrain one degree of freedom.
(*) we are talking about freely pivoted at both ends - each link only constrains the distance
between its ends.
