Median and Mode?
Is there a way to calculate the median and mode of a very large and randomly sized data set using the Yun? I am pulling in 1,000 to 3,000 readings from a sensor at a time and need to find the median and mode value of each unique data set. The data is written and stored on the SD card for future uploading so a script could be used to analyze the data set after it's collected. Though uploading the data set to a server for analysis is possible, it isn't ideal.
The data characteristics are such that the mean isn't relavent and eventually, the data sets could range in size from a few hundred samples to a few thousand samples.
lexical43:
What prevents you from running a Python or Lua script on the Yun to do so? :confused:
I have never coded in Python or Lua. Only recently started with Arduino. I have been looking at the P-Squared Algorithm, but not getting my head around how to convert into code.
lexical43:
Well, Lua is IMHO very easy to learn and it is nothing specific to (any) Arduino. Neither is Python but I have myself a "natural aversion" against Python and only use it if I do not have an alternative readily available. And Lua is readily available on the Linux side of a Yun, as OpenWRT is using it... :wink:
I am pretty sure if you get yourself a Lua interpreter for whatever OS you run on your computer (Windows, OS X or Linux), you will find very likely some implementation of such algorithm in Lua on the web (Google is your friend, just don't Bing it! :grin: ), which you can then use on your Yun...
Ralf
I agree with PCWorxLA.
I think using the Linux side to deal with a lot of data is more appropriate and, as he said, Python and Lua are very easy to learn.
