Hi guys,
I have this code,
I know it isnt very streamlined, but it what I have for now,
The plan is to filter out the noise on an accelerometer, I cant find a kalman filter that lets me easily use my acc module , its an analog module not iic. So i decided to have a go at making a basic filter,
The problem is that the servo goes all stuttery, and im not sure why.
The plan of the filter is to take ten readings and get their sum, then divide by 10 to get an average reading.
the I compare each seperate reading to the median, to determine ten "differences"
i then deal with any neg difference by multiplying the result by -1 if the difference is less than 0.
I then check if the difference is less than a threshold, if it is then the original reading is added to the sum of the "filtered median" and the count of accepted readings is increased,
from there i repeat everything and at the end i have a sum and a number to divide it by, in order to get a median that doesnt include ay outrageous readings,
this is then mapped and written to a servo.
it seems like it should work , but its sooooo jerky it isnt feasable to use,
does anyone have any advice on why it may be so jerky, or what i can do to maybe make it mroe streamlined and run quicker?
thanks, in advance,
#include <AcceleroMMA7361.h>
AcceleroMMA7361 accelero;
#include <Servo.h>
Servo servo;
int ser= 0;
//////////////variables for differences
int d1=0;
int d2=0;
int d3=0;
int d4=0;
int d5=0;
int d6=0;
int d7=0;
int d8=0;
int d9=0;
int d10=0;
///////////////////////////////readings on y axis
unsigned int y1;
unsigned int y2;
unsigned int y3;
unsigned int y4;
unsigned int y5;
unsigned int y6;
unsigned int y7;
unsigned int y8;
unsigned int y9;
unsigned int y10;
//////////////variables to calc medians
unsigned int median;
unsigned int filteredmedian =0;
int filtercount =0;
int result =0;
/////////////threshold for median and difference
int thresh =2;
servo.attach(9);
//////////////put servo to neutral
servo.writeMicroseconds(1500);
accelero.begin(13, 12, 11, 10, A0, A1, A2);
accelero.setARefVoltage(5); //sets the AREF voltage to 3.3V
accelero.setSensitivity(LOW);
//sets the sensitivity to +/-6G
accelero.calibrate();
///////////////reset filter variables
filteredmedian=0;
filtercount=0;
///////////make ten seperate readings
y1 = accelero.getYVolt();
delay(5);
y2 = accelero.getYVolt();
delay(5);
y3 = accelero.getYVolt();
delay(5);
y4 = accelero.getYVolt();
delay(5);
y5 = accelero.getYVolt();
delay(5);
y6 = accelero.getYVolt();
delay(5);
y7 = accelero.getYVolt();
delay(5);
y8 = accelero.getYVolt();
delay(5);
y9 = accelero.getYVolt();
delay(5);
y10 = accelero.getYVolt();
delay(5);
/////////////take sum of readings, divide for median
median=((y1+y2+y3+y4+y5+y6+y7+y8+y9+y10)/10);
////////////calc difference
d1 =(median - y1);
////////////take care of negative differences
if (d1<0){
d1=-d1;
///////////if below threshold, add reading to filtered sum
if((d1)<thresh){
filteredmedian = (filteredmedian+y1);
filtercount ++;
//////////repeat process 9 times more
d2 =(median - y2);
if (d2<0){
d2=-d2;
if((d2)<thresh){
filteredmedian = (filteredmedian+y2);
filtercount ++;
d3 =(median - y3);
if (d3<0){
d3=-d3;
if((d3)<thresh){
filteredmedian = (filteredmedian+y3);
filtercount ++;
d4 =(median - y4);
if (d4<0){
d4=-d4;
if((d4)<thresh){
filteredmedian = (filteredmedian+y4);
filtercount ++;
d5 =(median - y5);
if (d5<0){
d5=-d5;
if((d5)<thresh){
filteredmedian = (filteredmedian+y5);
filtercount ++;
d6 =(median - y6);
if (d6<0){
d6=-d6;
if((d6)<thresh){
filteredmedian = (filteredmedian+y6);
filtercount ++;
d7 =(median - y7);
if (d7<0){
d7=-d7;
if((d7)<thresh){
filteredmedian = (filteredmedian+y7);
filtercount ++;
d8 =(median - y8);
if (d8<0){
d8=-d8;
if((d8)<thresh){
filteredmedian = (filteredmedian+y8);
filtercount ++;
d9 =(median - y9);
if (d9<0){
d9=-d9;
if((d9)<thresh){
filteredmedian = (filteredmedian+y9);
filtercount ++;
d10 =(median - y10);
if (d10<0){
d10=-d10;
if((d10)<thresh){
filteredmedian = (filteredmedian+y10);
filtercount ++;
///////////get final filtered reading
result = filteredmedian/filtercount;
////////////map result limits to servo range
ser = map(result,1440,1850,2000,1000);
//////////////write to servo
servo.writeMicroseconds(ser);
///////////////serial prints for debugging
//Serial.println(y1);
//Serial.println(y2);
//Serial.println(y3);
//Serial.println(y4);
//Serial.println(y5);
//Serial.println(y6);
//Serial.println(y7);
//Serial.println(y8);
//Serial.println(y9);
//Serial.println(y10);
//Serial.println(median);
//Serial.println(filteredmedian);
Serial.println(filtercount);
Serial.println(result);
