Mega 10bits pwm - pwm mode
Goodmorning everybody!
I'm trying to implement 10bits resolution and 10kHz pwm frequency for my auto balancing robot.
Pololu - Dual VNH3SP30 Motor Driver Carrier MD03A (max pwm frequency 10kHz)
https://www.sparkfun.com/products/9947
https://www.pololu.com/product/1443
For the mega2560 16 bits timers are 1,3,4,5:
timer 1 for pin 11 12
timer 3 for pin 2 3 5
timer 4 for pin 6 7 8
timer 5 for pin 44 45 46
I want to use timer5 and here Advanced Arduino: direct use of ATmega counter/timers at the end of the page shows pem modes: Fast Pwm at different resolutions, phase correct, phase and frequency correct. I usually read balancebot codes using phase and frequency, but don't really know why and how to set it in code.
 #include <avr/io.h>
  void setup(){
   pinMode(44, OUTPUT);
   pinMode(45, OUTPUT);
  void loop(){
  main();
  void main(){
  // In the next line of code, we:
  // 1. Set the compare output mode to clear OC2A and OC2B on compare match.
  //    To achieve this, we set bits COM2A1 and COM2B1 to high.
  // 2. Set the waveform generation mode to fast PWM (mode 3 in datasheet).
  //    To achieve this, we set bits WGM21 and WGM20 to high.
  TCCR2A = _BV(COM2A1) | _BV(COM2B1) | _BV(WGM21) | _BV(WGM20);
//not able to understand HOW CAN I CHANGE THAT MODE
  // 1. Set the waveform generation mode to fast PWM mode 7 —reset counter on
  //    OCR2A value instead of the default 255. To achieve this, we set bit
  //    WGM22 to high.
  // 2. Set the prescaler divisor to 1, so that our counter will be fed with
  //    the clock's full frequency (16MHz). To achieve this, we set CS20 to
  //    high (and keep CS21 and CS22 to low by not setting them).
 // TCCR2B = _BV(WGM22) | _BV(CS20);
 TCCR5B = B10010;  // prescaling by 8 the system clock
  // OCR2A holds the top value of our counter, so it acts as a divisor to the
  // clock. When our counter reaches this, it resets. Counting starts from 0.
  // Thus 63 equals to 64 divs.
  // OCR2A = 63;
 OCR5A = 14970; // 66,8002672Hz
  // This is the duty cycle. Think of it as the last value of the counter our
  // output will remain high for. Can't be greater than OCR2A of course. A
  // value of 0 means a duty cycle of 1/64 in this case.
OCR5A = 0;
  while(1);
Moderator edit:
</mark> <mark>[code]</mark> <mark>
</mark> <mark>[/code]</mark> <mark>
tags added.
Well, you won't get both at the same time - that would imply a clock frequency of 10.24MHz. With the 16MHz AVR, you can clock your PWM at either 16MHz which will give you 10kHz PWM with slightly more than 10bits of resolution ("top" = 1600), or you can run 8MHz with somewhat less than 10bits resolution (top=800)
 // OCR2A = 63;
Assuming your comments are correct, you'd want to set OCR5A to 1599 to get 10kHz (16M/10k = 1600), and you'd have 0..1599 as your PWM choices.
I do not understand how to choose the right COM WGM snd CS for timer5... >:(
What does _BV() function set? the bits high?
This is the original code:
  // 1. Set the waveform generation mode to fast PWM mode 7 --reset counter on
  //    WGM22 to high.
  // OCR2A = 63;
  OCR5A = 1599; // 10kHz
  OCR5A = 0;
Yes, it sets a bit high in the register location used as an argument for the function.
It will all be explained in the data sheet for the ATmega 640-1280-1281-2560-2561
