Hi All, I am using a mega 2561 which I have up & running, and talking serially without any problems. However I now need to control some pins to turn on LED, select a chip etc. I have tried allocating a pin by: const int ledPin = 2; however this actually allocates the pin as pin 19 as used on the 2560 board. I have also tried using: const int ledPin = PE4; again no success, no matter where I allocate the ledPin, it always ends up on PORT D somewhere. I have a 2560 board, and allocating using the PORT does not work either, although using the board pin numbers does work.
Any help will be appreciated. Thanks Macca
