Hi all,
I've been following Nick Gammon's instructions to boot load and so far I have the following:
Atmega chip programmer.
Written by Nick Gammon.
Version 1.37
Compiled on Mar 29 2017 at 12:13:27 with Arduino IDE 10801.
Attempting to enter ICSP programming mode .................................
Entered programming mode OK.
Signature = 0x1E 0x98 0x01
Processor = ATmega2560
Flash memory size = 262144 bytes.
LFuse = 0xFF
HFuse = 0xD8
EFuse = 0xFD
Lock byte = 0xFF
Clock calibration = 0x94
Bootloader address = 0x3E000
Bootloader length = 7474 bytes.
Type 'Q' to quit, 'V' to verify, or 'G' to program the chip with the bootloader ...
Verifying ...
Verification error at address 3E000. Got: 0x00 Expected: 0x0D
My connections seem right.
But just to iterate...
I have an Arduino 256 Mega to a Chinese MEGA 2560
Pin connections are 50 to 50, 51 to 51, 52 to 52, 53 to RESET; respectively.
Version 1.37
Compiled on Mar 31 2017 at 08:04:40 with Arduino IDE 10801.
LFuse = 0xFF
HFuse = 0xD8
EFuse = 0xFD
Lock byte = 0xFF
Erasing chip ...
Writing bootloader ...
Committing page starting at 0x3E000
Committing page starting at 0x3FD00
Written.
Verifying ...
No errors found.
Writing fuses ...
LFuse = 0xFF
HFuse = 0xD8
EFuse = 0xFD
Lock byte = 0xEF
Done.
Programming mode off.
Type 'C' when ready to continue with another chip ...
But after uploading the blink sketch... I get this:
Sketch uses 1462 bytes (0%) of program storage space. Maximum is 253952 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 8183 bytes for local variables. Maximum is 8192 bytes.
avrdude: stk500v2_ReceiveMessage(): timeout
avrdude: stk500v2_getsync(): timeout communicating with programmer
An error occurred while uploading the sketch
"But after uploading the blink sketch... I get this:
An error occurred while uploading the sketch"
Double check the port you are using.
You may need to go to Preferences/Show verbose output during: and select upload so we can see more of what is going on if checking the right port doesn't fix your problem.
Also, make sure you are working with a board that is clear of all connections except your USB.
I can cause this failure by selecting the wrong port.
After selecting "UPLOAD" in Preferences->Show Verbose Output....
Archiving built core (caching) in: C:\Users\jrenta\AppData\Local\Temp\arduino_cache_304212\core\core_arduino_avr_mega_cpu_atmega2560_0c812875ac70eb4a9b385d8fb077f54c.a
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega2560 -cwiring -PCOM7 -b115200 -D -Uflash:w:C:\Users\jrenta\AppData\Local\Temp\arduino_build_174788/Blink.ino.hex:i
avrdude: Version 6.3, compiled on Jan 17 2017 at 12:00:53
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
Using Port : COM7
Using Programmer : wiring
Overriding Baud Rate : 115200
AVR Part : ATmega2560
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PA0
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Can any one find anything wrong in this verbose output?
I can't upload any sketches into this Chinese board.
I have boot loaded it successfully, my drivers for the CH340 are downloaded and good to go.
Using Port : COM7
PAGEL : PD7
BS2 : PA0
RETRY pulse : SCK
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
@Halekoa_Veteran, If you uploaded a sketch using "Upload using Programmer" the bootloader is erased and you can no longer use the upload button until you re-burn the bootloader.
