Hey all,
So, I’m currently trying to create an Arduino controlled Hot Wheels track, with photoresistors doing the heavy lifting for when a car passes the start and finish points. However, I also want to calculate the time that a car took to travel down the track (this will allow me to later calculate the speed of the car) so I am trying to use the millis() function. The problem is that it causes the program to continuously restart.
Here is my code (with the offending code commented out):
* Created by Jivan RamjiSingh
* Code for a semi-full scale 6 lane track setup
* 12 Photoresistors, 2 per lane
* 7 LEDs, 1 per lane + 1 "ready"
const char lightPin[] = {3, 4, 5, 6, 7, 8, 2};
const char topPho[] = {A0, A1, A2, A3, A4, A5};
const char botPho[] = {A6, A7, A8, A9, A10, A11};
int topVal[5] = {};
int botVal[5] = {};
int trigTopVal[5] = {};
int trigBotVal[5] = {};
unsigned long startTime = 0;
unsigned long endTime = 0;
unsigned long elapsedTime = 0;
boolean topTrig = true;
boolean botTrig = true;
Serial.println("Initializing");
Serial.print("Configuring LED pin outputs: ");
for (int n = 0; n < 8; n += 1) {
Serial.print(n);
Serial.print(" ");
pinMode(lightPin[n], OUTPUT);
digitalWrite(lightPin[n], LOW);
Serial.print("Setting up lane: ");
for (int i = 0; i < 6; i += 1) {
Serial.print(i);
Serial.print(" ");
topVal[i] = analogRead(topPho[i]);
botVal[i] = analogRead(botPho[i]);
trigTopVal[i] = (0.75 * topVal[i]);
trigBotVal[i] = (0.75 * botVal[i]);
digitalWrite(lightPin[6], HIGH);
int botValue = analogRead(A6);
int topValue = analogRead(A0);
if ((botValue <= trigBotVal[0]) && (botTrig)) {
digitalWrite(3, HIGH);
botTrig = false;
//endTime = millis();
//elapsedTime = (endTime - startTime);
//elapsedTime = (elapsedTime / 1000);
//Serial.println(elapsedTime);
Serial.println("Triggered bottom photoresistor");
if ((topValue <= trigTopVal[0]) && (topTrig)) {
digitalWrite(4, HIGH);
topTrig = false;
//startTime = millis();
Serial.println("Triggered top photoresistor");
This code outputs the following on serial:
Initializing
Configuring LED pin outputs: 0 1 2 3 4 5 6 7
Setting up lane: 0 1 2 3 4 5
However, if I remove the comments, then I get this output (repeating forever):
Initializing
Configuring LED pInitializing
Configuring LED p⸮Initializing
Configuring LED pin ⸮Initializing
Thank you!
