Mega 2560 not able to upload servo example (only on this PC)
Hello together,
I recently buyed a Mega 2560 Board and unfortunately I´m unable to upload the servo example SWEEP onto my board. I tried on other PCs and there it worked without any problem. I tried serveral arduino software versions... nothing worked. I'm distressed right now, if anybody could give me a hint, I would be very glad!
My failure Code is as follows
Arduino: 1.5.6-r2 (Windows 7), Board: "Arduino Mega or Mega 2560, ATmega2560 (Mega 2560)"
C:\Users\flieger\Documents\Arduino\libraries\Servo\Servo.cpp: In member function 'uint8_t Servo::attach(int)':
C:\Users\flieger\Documents\Arduino\libraries\Servo\Servo.cpp:28: error: 'digitalWrite' was not declared in this scope
C:\Users\flieger\Documents\Arduino\libraries\Servo\Servo.cpp:29: error: 'OUTPUT' was not declared in this scope
C:\Users\flieger\Documents\Arduino\libraries\Servo\Servo.cpp:29: error: 'pinMode' was not declared in this scope
C:\Users\flieger\Documents\Arduino\libraries\Servo\Servo.cpp: In member function 'void Servo::write(int)':
C:\Users\flieger\Documents\Arduino\libraries\Servo\Servo.cpp:52: error: 'clockCyclesPerMicrosecond' was not declared in this scope
C:\Users\flieger\Documents\Arduino\libraries\Servo\Servo.cpp: In static member function 'static void Servo::refresh()':
C:\Users\flieger\Documents\Arduino\libraries\Servo\Servo.cpp:74: error: 'millis' was not declared in this scope
C:\Users\flieger\Documents\Arduino\libraries\Servo\Servo.cpp:107: error: 'digitalWrite' was not declared in this scope
C:\Users\flieger\Documents\Arduino\libraries\Servo\Servo.cpp:109: error: 'TCNT0' was not declared in this scope
C:\Users\flieger\Documents\Arduino\libraries\Servo\Servo.cpp:124: error: 'digitalWrite' was not declared in this scope
Why are you using 1.5.6 for a Mega?
First I also tried Version 1.0.5 r2 but the problem was always the same. I use WIN 7 64Bit. On the PCs in my University and other PCs everything works fine,just mine is making these problems. All the settings are the same (as far as I can influence them).
Ok, after installing the arduinosoftware a couple of times it suddenly works now!!!!
