I am designing a PCB that uses a Mega2560 Pro mini as its main MCU that will be plugged into a PC. Only problem is to simplify the PCB design process I had to flip the 2560 wrong way around so that the USB port faces the wrong direction. I would like to find a way to rectify this issue. I have come up with 2 ideas but I Don't know if they are possible.
A small USB jumper cable that connects the port on the 2560 to a port on the pcb right next to the MCU then run traces down the port to a more convenient spot on the PCB where I could plug in from my PC.
use the TX/RX pins on the 2560 as the hardware serial ports to carry the USB signal. Issue with this is I am not uploading any code to the 2560 as it runs its own specific firmware. so Those pins would have to carry usb as an inherit function of the underlying process.
I do not quite understand the problem; unless you have also designed a case (or have an existing case) where the hole for the USB is already implemented.
Regarding your first idea, using a small USB jumper cable sounds feasible, especially if you can find a way to route the traces effectively on the PCB to a more convenient spot for plugging into your PC. However, it might add complexity and potential points of failure.
For your second idea, repurposing the TX/RX pins to carry USB signals could be tricky. While it's possible to transmit data through these pins, USB communication involves more than just serial data transfer. You'd need a USB-to-serial converter to handle the protocol conversion. Additionally, if you're not uploading code to the 2560, ensuring that these pins can still carry USB signals as part of the firmware's underlying process might require some deeper exploration into the firmware functionality.
Have you considered exploring other options like modifying the PCB layout to accommodate the correct orientation of the Mega2560 Pro mini? It might involve redesigning certain components or traces, but it could simplify the overall setup and avoid potential complications.
