Microcontroller Arduino Mega 2560:
A DCC-signal has this kind of bitvalue encoding like shown in the picture
A bit-value of 1 is encoded into a 50%-duty-cycle with 58µsec HIGH and 58 µsec LOW
A bit-value of 0 is encoded into a 50%-duty-cycle with 100µsec HIGH and 100 µsec LOW
Is there a special name for this way of bitvalue-econding?
A hardwaretimer inside the Mega 2560 can be configured to fast-pwm-mode.
First I want to describe it in general words without using the register-names.
My understanding of the fast-pwm-mode so far is:
The counter-register continuosly counts up from zero to a max-value and then is reset to zero.
Resetting the counter-register to zero can be triggered by different registers.
What these different kinds of resetting the counter-register have in common is:
If the allways counting up counter-register-value matches the value of configuration-register then the counter-register will be reset to zero.
If all involved registers are configured in the correct way.
The hardware-timer will switch the configured IO-pin LOW/HIGH
without a single line of code
= independent creation of the PWM-signal.
As the DCC-signal needs
a cycle-time of 116 µseconds for a bitvalue 1 (58 µsecs HIGH / 58 µsecs LOW)
and
a cycle-time of 200 µseconds for a bitvalue 0 (100 µsecs HIGH / 100 µsecs LOW)
The values inside the registers that control the cycle-time must be changed each time
the bitvalue changes.
As there can be any kind of bitpattern where at each bit-position there can be a 1 or a 0
each and every bit must be checked for its value beeing 1 or 0
and then setting register-values to make the "PWM-module" create a cycletime of 116 µseconds or 200 µseconds
The point in time to set the new cycle-time (116 µsec or 200 µsec) is always the end of each cycle.
This means the interrupt-control-registers must be configured to invoke an interrupt each time when a single pwm-cycle has finished.
The ISR-function takes the next bit of the DCC-message and sets that registers of the hardware-timer that control the cycle-time.
example send a byte with values 10011011
76543210
10011011
take bit 0 which has value 1 => set cycletime to 116 µseconds
if 116 µseconds have passed by an interrupt is invoked and the ISR-code does
take bit 1 which has value 1 => set cycletime to 116 µseconds
take bit 2 which has value 0 => set cycletime to 200 µseconds
if 200 µseconds have passed by an interrupt is invoked and the ISR-code does
take bit 3 which has value 1 => set cycletime to 116 µseconds
take bit 7 which has value 1 => set cycletime to 116 µseconds
After sending bit 7 one byte is send.
If message has mutliple bytes take next byte, reset bitcounter to 0
repeat processing all bits from bit 0 to bit 7
As switching of the IO-pin is done on the event
"value of counter-register matches some other register"
changing the value of the "match"-register right at the start of a cycle will work for pwm-frequencies that are not too high.
Example:
pwm-frequency results in a matchvalue of 1000
right at the beginning of a cycle the counter-register has value 0
now executing the commands for changing the cycletime needs some time
after this execution-time the counter-register (which is free running always counting up)
has reached value 350 which is below 1000
changing the match-value to 1500 is done before the matching is reached
result: cycletime longer
for changing the "match"-value back from 1500 to 1000 there is even more time
And as executing the code for changing the "match"-value takes only 350 counts
this works.
And using a single interrupt always invoked at the end of a pwm-cycle is sufficient to make it work.
Is this a correct description so far?
