Mega 2560 servo pins & Fio AREF
  1. What pins are for each timer, to use servos? I'll be putting between 15 and 20 servos on one 2560.
  2. To do battery sensing of a 7.4 2S LiPo pack on a FIO, would I just use the analogReference(INTERNAL) and a 25K/10K voltage divider?
Hi
Servos can go on any pin if you are using the servo library, or try this trick to put all of them on one pin -
Duane B
rcarduino.blogspot.com
DuaneB:
Hi
RCArduino: Arduino Serial Servos
Duane B
Well it says 48 servos...the mega has 53 digital and 16 analog..which pins go to which timers?
Going to have only 2 or 4 servos themselves. The other 13-15 will be motors running on ESC's....and not just little ones. The robot will be running on 2 optima yellow tops if that says anything. If there's room, might fit 4 of the buggers and ignore the 80 pound penalty. 4 motors would be nice but there's only so much room, and only so much you gain in a pull-pull situation.
Again - Any Pins, it has nothing to do with timers.
In the background, the servo library is using a timer to tell it when to toggle the servo pins, the actual toggling is done in software and is not connected to timer pins in anyway whatsoever, so just choose which pins you want - any of them - and crack on.
There is a simplified overview of what the library does to manage a servo on any pin here -
Duane B
Here is a spreadsheet that states what pins are on what timers. https://spreadsheets.google.com/pub?key=rtHw_R6eVL140KS9_G8GPkA&gid=0
