Ok so i think the problem is definitely in the header, so this is the direction i’ve taken:
sparkfun header:
#define CC3000_INT 3 // Needs to be an interrupt pin (D2/D3)
#define CC3000_EN 5 // Can be any digital pin
#define CC3000_CS 10 // Preferred is pin 10 on Uno
// Connection info data lengths
#define IP_ADDR_LEN 4 // Length of IP address in bytes
// WiFi Constants
char ap_ssid[] = "HOME-61B2"; // SSID of network
char ap_password[] = "REMOVED"; // Password of network
unsigned int ap_security = WLAN_SEC_WPA2; // Security of network
unsigned int timeout = 30000; // Milliseconds
// Global Variables
SFE_CC3000 wifi = SFE_CC3000(CC3000_INT, CC3000_EN, CC3000_CS);
SFE_CC3000_Client client = SFE_CC3000_Client(wifi);
M2XStreamClient m2xClient(&client, m2xKey);
stock adafruit header:
#include <Adafruit_CC3000.h>
#include <ccspi.h>
#include <SPI.h>
#include <string.h>
#include "utility/debug.h"
// These are the interrupt and control pins
#define ADAFRUIT_CC3000_IRQ 3 // MUST be an interrupt pin!
// These can be any two pins
#define ADAFRUIT_CC3000_VBAT 5
#define ADAFRUIT_CC3000_CS 10
// Use hardware SPI for the remaining pins
// On an UNO, SCK = 13, MISO = 12, and MOSI = 11
Adafruit_CC3000 cc3000 = Adafruit_CC3000(ADAFRUIT_CC3000_CS, ADAFRUIT_CC3000_IRQ, ADAFRUIT_CC3000_VBAT,
SPI_CLOCK_DIVIDER); // you can change this clock speed
#define WLAN_SSID "HOME-61B2" // cannot be longer than 32 characters
#define WLAN_PASS "0C6B7DEB3241400F"
// Security can be WLAN_SEC_UNSEC, WLAN_SEC_WEP, WLAN_SEC_WPA or WLAN_SEC_WPA2
#define WLAN_SECURITY WLAN_SEC_WPA2
#define IDLE_TIMEOUT_MS 3000 // Amount of time to wait (in milliseconds) with no data
// received before closing the connection. If you know the server
my failed attempt to combine:
#include <SPI.h>
#include <ccspi.h>
#include <jsonlite.h>
#include <M2XStreamClient.h>
#include <Wire.h>
//#include "M2XStreamClient.h"
// Parameters
#define POST_DELAY_MS 10000 // Post to stream every 10 seconds
// WiFi Constants
#define WLAN_PASS "REMOVED"
// Global Variables
Adafruit_CC3000 wifi = Adafruit_CC3000(ADAFRUIT_CC3000_CS, ADAFRUIT_CC3000_IRQ, ADAFRUIT_CC3000_VBAT);
Adafruit_CC3000_Client client = Adafruit_CC3000_Client(wifi);
M2XStreamClient m2xClient(&clientm2xKey);
the error report for the above is:
Sketch1.ino:72:60: error: no matching function for call to 'Adafruit_CC3000_Client::Adafruit_CC3000_Client(Adafruit_CC3000&)'
:Adafruit_CC3000_Client client = Adafruit_CC3000_Client(wifi);
Sketch1.ino:candidates are
Sketch1.ino:In file included from
Adafruit_CC3000.h:Adafruit_CC3000_Client(const Adafruit_CC3000_Client&)
:Adafruit_CC3000_Client(const Adafruit_CC3000_Client& copy);
Adafruit_CC3000.h:no known conversion for argument 1 from 'Adafruit_CC3000' to 'const Adafruit_CC3000_Client&'
Adafruit_CC3000.h:Adafruit_CC3000_Client()
:Adafruit_CC3000_Client(void);
Adafruit_CC3000.h:candidate expects 0 arguments, 1 provided
Adafruit_CC3000.h:Adafruit_CC3000_Client(uint16_t)
:Adafruit_CC3000_Client(uint16_t s);
Adafruit_CC3000.h:no known conversion for argument 1 from 'Adafruit_CC3000' to 'uint16_t {aka unsigned int}'
M2XStreamClient.h:In file included from
Sketch1.ino:from
EDIT: upgrading firmware to 1.4 solved the problem… for now…
