Hi there,
Im very new at all of this and ive built a ambilight setup and saw this project and was wondering if anyone knows how to convert his code to use a Mega 2560?
http://code.google.com/p/unolight/
Thanks for any help
Carl
* UnoLight - Atmolight Arduino Client for ATmega 328p versions (Tested with ATmega 328p on Arduino UNO R2)
* Copyright 2011 by Oskar Wicha
Color | Arduino Uno Pins for
| LED1 LED2 LED3 LED4
BLUE 2 5 8 11
GREEN 3 6 9 12
RED 4 7 10 13
//#ifndef __AVR_ATmega328P__
//#error Code created for ATmega 328p and Arduino UNO. To compile for another Arduino boards you will need to change register names in source code.
//#endif
#define NUM_LEDS 6 // max number of RGB LEDs (ATmega 328p in Arduino UNO or NANO 3.0 sypports only up to 4 RGB LEDs on 12 output pins)
#define IDLE_TIME_LIMIT 5530 // time (in seconds) without data transmision after which LEDs will by turn off
#include <avr/io.h>
#include "ledPorts.h"
#include "macros.h"
#include "gammaTable.h"
volatile uint16_t ledChannels[NUM_LEDS][3] = {0};
boolean ledsOff = false; // flag indicating if LEDs ar OFF or ON
uint8_t incomingAtmo[16]; // buffer array for incomming data over serial
// order is reversed, first uint8_t is last module in the chain
// 0=sum,1=left,2=right,3=top,4=bottom
const uint8_t channelOrder[NUM_LEDS] = {1,2,3,4,0,0};
uint32_t timeOfLastTransmition = millis(); //stores time of last serial transmition
cli();
DDRD |= 0xFC; // direction variable for port D - make all pins outputs except serial pins 0 & 1
DDRB |= 0xFF; // direction variable for port B - all outputs
//----------------Initialize Interupts------------------
initTimer2();
//----------------Initialize serial connection ---------
Serial.begin(38400); // Setting serial speed correct for Atmolight
sei(); // Enable global interrupts
getAtmoCommand();
// TIMER2 Overflow interrupt
ISR(TIMER2_OVF_vect)
static uint16_t pwmCounter;
volatile uint16_t *ledValPtr = &(ledChannels[0][0]);
cli();
//LED 1
(*ledValPtr++ >= pwmCounter) ? LEDON(PORTD,LED1_RED_PIN) : LEDOFF(PORTD,LED1_RED_PIN);
(*ledValPtr++ >= pwmCounter) ? LEDON(PORTD,LED1_GREEN_PIN) : LEDOFF(PORTD,LED1_GREEN_PIN);
(*ledValPtr++ >= pwmCounter) ? LEDON(PORTD,LED1_BLUE_PIN) : LEDOFF(PORTD,LED1_BLUE_PIN);
//LED 2
(*ledValPtr++ >= pwmCounter) ? LEDON(PORTD,LED2_RED_PIN) : LEDOFF(PORTD,LED2_RED_PIN);
(*ledValPtr++ >= pwmCounter) ? LEDON(PORTD,LED2_GREEN_PIN) : LEDOFF(PORTD,LED2_GREEN_PIN);
(*ledValPtr++ >= pwmCounter) ? LEDON(PORTD,LED2_BLUE_PIN) : LEDOFF(PORTD,LED2_BLUE_PIN);
//LED 3
(*ledValPtr++ >= pwmCounter) ? LEDON(PORTB,LED3_RED_PIN) : LEDOFF(PORTB,LED3_RED_PIN);
(*ledValPtr++ >= pwmCounter) ? LEDON(PORTB,LED3_GREEN_PIN) : LEDOFF(PORTB,LED3_GREEN_PIN);
(*ledValPtr++ >= pwmCounter) ? LEDON(PORTB,LED3_BLUE_PIN) : LEDOFF(PORTB,LED3_BLUE_PIN);
//LED 4
(*ledValPtr++ >= pwmCounter) ? LEDON(PORTB,LED4_RED_PIN) : LEDOFF(PORTB,LED4_RED_PIN);
(*ledValPtr++ >= pwmCounter) ? LEDON(PORTB,LED4_GREEN_PIN) : LEDOFF(PORTB,LED4_GREEN_PIN);
(*ledValPtr++ >= pwmCounter) ? LEDON(PORTB,LED4_BLUE_PIN) : LEDOFF(PORTB,LED4_BLUE_PIN);
(pwmCounter < 1023) ? pwmCounter++ : pwmCounter = 0;
TCNT2 = 0xff; // necessery for not triggering commperator ISR also sets frequency
sei();
//---------------ADDITIONAL FUNCTIONS----------------------------
inline void initTimer2()
// Initialize TIMER2
TCCR2B &= ~_BV(WGM22);
TCCR2A |= _BV(WGM21);
TCCR2A &= ~_BV(WGM20); // Fast PWM
TCCR2B |= _BV(CS22);
TCCR2B &= ~_BV(CS21);
TCCR2B &= ~_BV(CS20); // Timer Prescaler 64
TIMSK2 |= _BV(TOIE2); // Enable Overflow Interrupt
TCNT2 = 0;
TIMSK1 &= ~_BV(TOIE1); // turn off Timer1 (not used interrupt)
inline void turnOffLEDArray()
// Turn off all LEDs an Timer2 interrupt
TIMSK2 &= ~_BV(TOIE2);
PORTD = 0x00;
PORTC = 0x00;
ledsOff = true;
// get LED values sent over serial (Atmolight protocol)
inline void getAtmoCommand()
if( Serial.available() > 18 && Serial.read() == 0xff && Serial.read() == 0x00 && Serial.read() == 0x00 )
uint8_t i = 0;
while( i < 16 )
*(incomingAtmo + i++) = Serial.read();
volatile uint16_t *ledChannelAndColorPointer = &ledChannels[0][0];
cli();
uint8_t channel = 0;
while( channel < NUM_LEDS )
uint8_t *incomingValuePointer = incomingAtmo + *(channelOrder + channel++) * 3 + 1;
*ledChannelAndColorPointer++ = *(gammaTable + *incomingValuePointer++); // red
*ledChannelAndColorPointer++ = *(gammaTable + *incomingValuePointer++); // green
*ledChannelAndColorPointer++ = *(gammaTable + *incomingValuePointer); // blue
sei();
if(ledsOff)
TIMSK2 |= _BV(TOIE2); // LEDs ON
// turn off leds if no data for defined period of time
if( millis() - timeOfLastTransmition > IDLE_TIME_LIMIT * 1000 )
turnOffLEDArray();
